#19 |
![]() Drives: vitz 06 Join Date: Nov 2010
The only problem is that it is not illuminating i just mailed pivot lets see i will keep you posted if you dont mind sir
#20 |
![]() Drives: 08 liftback 5 speed Join Date: Jul 2009
Cars have been started with keys since just after WWII (OK, not sure about that) for a reason. The only cars I ever had with start buttons had them because I bypassed bad wiring or key switches. I really don't get why start buttons are all the rage right now- they seem pre-tailfin to me.
#21 |
Rollerskate
hey scott is there a way to start the car with the push start and not have to have the key at all like a switch you can hide and flip when you wanna hit the pts butten
Its a roller-skate get it right add me on facebook if your from nc my email for facebook is drifter704@yahoo.com |
#22 |
You would have to remove the lock cylinder to get rid of the steering column lock. That eliminates a level of security for theft of your car, but if your 09 has the engine immobilizer, you would still need to wave the key by the receiver (the black rings around the key switch) to allow the car to start.
#23 |
Rollerskate
i dont have a chip its just a key and hey if you could or if you ever get a chance could you show me what wires i need to hook the new button that way when you have it off you cant do noting and with it on you can sttart the car listen to the radio every thing like a key but without the key
#24 | |
#25 |
![]() ![]() ![]() Drives: 1986 Toyota Corolla Join Date: May 2009
CTScott, do you think it would be possible to use the PTS system from a Lexus, that uses no keys at all, just sensors? Or is that a function that is limited by the ECU?
#26 | |
There is a complete aftermarket system that has been discussed on MI: http://www.microimageonline.com/foru...-Entry-for-279
#27 |
Rollerskate
hey scott I see that you said you made a pts setup how does your work I don't have a chip in the key and don't have power but I really don't wanna use the key other then to unlock the doors I wanna have mine set like a rally car flip a switch and then hit the button to start the car no keys
#28 | |
For what you are looking to do, you would basically be replacing the keyswitch with your flip switch and then could use my module, or just a simple momentary switch for cranking the starter. The one downside to what you are thinking of doing is that without the key/steering column lock or the engine immobilizer it would be very easy for someone to steal your car.
#29 |
Rollerskate
hell if someone wants my car ill give them a hr head start then call and say someone stole it i like my car and hate it at the same time
#30 |
if i install your pts module and i dont have the factory immobilizer do i still need to put the key in the ignition switch??
iSRA |
#31 |
Yes. To unlock the steering column.
#32 |
is there a way to do it so that i dont need the key
iSRA |
#33 |
At this point not really. If I get around to adding the RFID interface to it, then that will completely take the place of the key.
#34 |
![]() Drives: Vitz 2006 Join Date: Jan 2021
Hey scoty i converted my yaris to totally push start with keyles entry.i change things
changed the complete dash board wiring of push start yaris Smart card ecu Smart door receiver control Push start button And given attached 3 antenas. And door handles and its wiring.but im facing my door sensor wlare nit working i think due to wiring.they dont detect my key remote when i near i had to unlock manually by remote with unlock button.can anyone help regarding door wiring? |
| GB- Push to Start , With SMART ENTRY | 1NZYaris1 | Items for Sale by private party | 32 | 12-07-2011 01:10 AM |
| FS: Push to Start Trim Piece | CTScott | Items for Sale by private party | 36 | 05-28-2010 12:42 PM |
| Push Button Start | Stoln | Europe (continental) | 20 | 05-24-2010 07:56 AM |
| push start vs electric start? | yaris2010RS | General Yaris / Vitz Discussion | 18 | 04-07-2010 02:20 PM |
| push to start engine button DIY (done) | yarismo | DIY / Maintenance / Service | 6 | 03-31-2010 04:21 PM |
