![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Hey guys
Has anyone attempted to run a line from D3 to AD4 as described on pages 7 and 8..? AD4 looks fairly accessible from the photo, but I have not had the chance to check myself. Thanks |
#2 | |
AD4 is under the top of the dash. You have to remove the dash top to get to it. Also, the wire from the ECM to AD4 is only there in 2009 sedans and 2009+ Puerto Rico cars.
Hi Scott.. Maybe we Canuks are lucky in this case, my 08 Sedan has the wire at the ECM, and I can only assume it connected at AD4
I had to confirm and took apart the ECN connector and snapped a photo.. Like you indicated, it appears that there is no access to the AD4 connector from under the dash, but wonder why Toyota/Rostra would put out these instructions if it was not possible? Maybe to mess with our Cruise Control crazy minds :p |
#4 | |
I thought you did an excellent job with it. Now, we just need one for the 2008 and older cars that require the ECM and steering column pins to be added.
#7 | |
Connector location under dash (the gray connector next to the blue and yellow connectors at the top left section of this picture): Conn AD4 - Location2.jpg More detail on the connector's location (this is the male side {which is on the bottom when in place in the car} of the junction connector that is part of the dash harness): Conn AD4 - Location.jpg This is how the male pin gets inserted into the connector: Conn AD4 - Pin Insertion.jpg Detail of the male pin: Conn AD4 - Male Pin.jpg
![]() Drives: 2006 canadian 3 door hatchback Join Date: Jan 2011
problem
got everything installed bud it do not work!
so ran a cable from pin 40 of the ecm to pin 1 of d3 grounded from pin 2 of d3 to a bolt of the column installed the stalk with the new wire the horn works fine. i suspect the ground but its minus 15 celcius in the driveway so i'll check that out again tommorrow, anything i should test for if it's not the ground wire, im reading about that ad4 thiing do i miss something? 2006 canadian yaris HB automatic |
#9 | |
#10 | |
I assume you have an Automatic, since you don't mention installing the clutch switch? AD4 is the middle connection point. Some years/configurations of the Yaris have the pin from ECM A21-40 to AD4, but then lack the wire from AD4 to D3. In your case, if you had to add A21-40, then AD4 is not of interest. For testing, if you have a multimeter, I would start with measuring the voltage on pin 1 of D3 with the ignition on - It should measure 12V, indicating that the connection from D3 to the ECM is good. Next, unplug D3, and with an ohm meter, measure the resistance between pins 1 and 2 on the column. It should measure as open, and then if you hold in the on/off button on the stalk it should go to a dead short.
#11 | |
Scott.. Would you happen to have a photo the the top half of AD4 connector as I got the connector off the white mount, but since it is a bit tight, I am having a hard time trying to find the latch to unhook the two halfs?..
Thanks Scott! Quote:
#12 | |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
