Old 02-13-2011, 01:11 PM   #1
rapev-8
Drives: toyota
2010 engine break in period?
hello everyone, just bought a new 2010 yaris 2 dr hb and my question for today is break in period?
i know alot of cars back in the days you will need to drive under 3500 rpm for 500 miles before you can beat on it :) (kinda like a new clutch put in a car) does it still apply here on my lil car?
rapev-8 is offline   Reply With Quote
Old 02-13-2011, 01:31 PM   #2
cougar65
cougar65's Avatar
Drives: 2010 yaris 5door
I just babied it for te first 500 then just started driving it like I would any car. It's strange how it's not in writing any break in instructions...
cougar65 is offline   Reply With Quote
Old 02-13-2011, 02:21 PM   #3
Hershey
Think it's 1,500 mile break in period stated in manual . I always change oil and filter not long after that .
Old 02-14-2011, 10:38 AM   #4
rapev-8
Drives: toyota
should i change the oil myself or take it to the dealer? cause i got that stupid "toyota care" and thats every 6 months or 5000 miles.
Old 02-14-2011, 11:37 AM   #5
Hershey
That's up to you . If you do change the oil and filter make sure to save the receipts and to record the mileage , date , type of oil used ( weight + brand ) in your service manual . The oil change is very easy . I do it myself because I make sure not to overfill , spill oil , and know oil filter is tighened properly . We've had / seen where they forgot to put the oil in , overfill engine up to a quart , and not install oil filter properly so it leaked oil to th point of the engine loosing over 3 quarts . Maybe your experiences have / will be better than ours .
Old 02-14-2011, 10:55 PM   #6
cool_beans00
Drives: 2004 Corolla
Page 122 in the owner's manual
For the first 200 miles avoid sudden stops
for the first 500 miles do not tow
for the first 1000 miles
do not drive at extremely high speeds (you should never drive extremely high speeds imo)
avoid sudden acceleration
do not drive continuously in the low gears
do not drive at a constant speed for extended periods
unfortunately it doesn't say how long an "extended period" is? an hour? 2 hours?
cool_beans00 is offline   Reply With Quote
Old 02-15-2011, 10:59 AM   #7
rapev-8
Drives: toyota
ok, so maybe 1000 miles before i can beat on it :) yea i never let anyone else do my oil change beside myself, but try doing my IS300 or the 98 4runner v6 could be a b*tch. but i ll be doing the first oil change myself then
Old 02-15-2011, 11:53 AM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
wow.. really? i had a little over 500 miles on my car when i took it out to autocross the following weekend.... ooopsie
Old 02-16-2011, 12:00 PM   #9
rapev-8
Drives: toyota
yea man not a good idea!
Old 02-16-2011, 10:35 PM   #10
Hershey
Then why does TOYOTA have a break in period that suggests a certain type of driving in the owners manual ?
Old 02-16-2011, 10:49 PM   #11
enviri
enviri's Avatar
Drives: 2010 Yaris
i beat the shit out of my car day 3. that's 500 miles in. i got bored babying the new car.
enviri is online now   Reply With Quote
Old 02-16-2011, 11:12 PM   #12
RedRide
RedRide's Avatar
Originally Posted by cdydjded View Post
New cars do not require break-in periods. That is 1970's thinking.
Actually they still do.
Even though modern enging do not require the break in of old,
Engine parts still have to wear in together.
Engine parts also tend to wear in together better if the speed is varied a bit for the first 200 miles or so.
The prime reason why modern engine do not require break ins like in years past is because modern machine tools are much more precise making tolerences tighter. They still need to wear in together though.
I'm not getting into the how long a break in should be argument......I know better
Old 02-17-2011, 02:55 AM   #13
yaris2010RS
yaris2010RS's Avatar
so u go by what toyota says like its the bible but feel they are buffoons?
i was very gentle on my car for the first 3000km and i was told to stay off the highway.
Old 02-17-2011, 09:36 AM   #14
brg88tx
Drives: 07 Yaris Sedan, Auto
all y'all worried about the break in period should also realize that unless your car had 0 miles on it when you bought it, it's likely been on at least 5 test drives and nearly everyone on a test drive floors it to test the car's pickup.
brg88tx is offline   Reply With Quote
Old 02-17-2011, 11:35 AM   #15
ilikerice
ilikerice's Avatar
well, the way i look at it. i have the skill and the tools to pull out engines and do my own mechanical work. thank god for warranties. someone once told me a toyota engine is never actually "broken in" until around 100,000 miles
Old 02-17-2011, 01:31 PM   #16
RedRide
RedRide's Avatar
Add to that the car was driven off the assembly line in Japan into a storage lot.
Then driven/loaded onto a carrier to transport it to a dock.
From there, driven/loaded onto a ship bound for America, etc.
Then driven off the ship to another storage lot, then driven onto a car carrier/train car and transported again.
Then, perhaps another car carrier before it reaches your dealer.
As someone who worked at an auto assembly plant in the past, I can tell you the cars are jockied quickly so......
However, these are only brief perieds and there is no reason to add insult to injury and continue the abuse when you get it as parts are still not broken in and damage can still be done.
Also all this loading/ unloading and test drives are not nearly as bad as someone getting a new car and imeadiately driving it from NY to Flordia (for example) and running it at a constant 3k RPM (for example) before any real break in has occured.
Old 02-17-2011, 01:59 PM   #17
RedRide
RedRide's Avatar
I nor anyone here can intelligently answer that question. None of us are Toyota engineers. I can tell you this, engines today are built completely different than 40yrs ago. Fuels, oil viscosities are all 100 times better than the 1970's. Most engines today are aluminum as opposed to cast iron. We have fuel injection & ECU's that control everything. Cant compare 1970's to now.
Yes but, piston rings and cylinder walls are still cast iron or cylinder walls are plated with a better weaing metal than what is used for the block.
Even if the block is aluminum, it still has a cast iron/plated cylinder sleeve. Bearing and crankshafts for example are still made basically the same
Basically, the only thing made of aluminum are non wear items and critical bearings/mating surfaces are stiil cast iron or steel.
Aluminum an other alloys are used prmarily just to save weight, not for better wear properties.
Granted, oil is much better but, parts still have to wear in to one extent or another.
Capice?
Old 03-02-2011, 12:59 AM   #18
bear4
Drives: 2007 yaris
Why driving at constant 3k RPM is bad? I got my brand new car in GA and drove 5hrs to FL at 3k rpm, did not have any problems...
bear4 is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 09:02 AM
