Old 03-01-2011, 10:51 AM   #9
MUSKOKA800
MUSKOKA800's Avatar
I can tell you that 14" Echo steelies are significantly lighter than 15" Yaris Alloys.
I was shocked when I did the first change-over. Braking is unreal with the lighter set-up. Accelleration, while noticabley stronger, is aided by the gear ratio advantage of the smaller diameter winter tires on the 14's then.
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
175/60/14 OEM Tyre Weight hazzy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-07-2010 03:23 AM
I NEED A 15" STEEL RIM AND OEM TIRE robkay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 12-18-2009 10:57 AM
Weight Reductions scape General Yaris / Vitz Discussion 34 06-08-2009 02:31 PM
Stock 15" RS 5 Spoke Rim weight? GabL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-03-2006 05:23 PM
