Old 07-25-2015, 02:54 PM   #1
masterpipo1
Drives: Yaris Sedan 2007 W/O Power
Hi !
i did every step for the cruise control stalk, i didnt do any wiring yet cause i dont know if i need to do it.
In the tutorial, they said that i need to look at the D3 Connector here what my panel look like
I think that my D3 connector is no 1. if not , can you guys tell me which connector i need to look at. On this connector , i see the pink and blue wire,i dont see any black wire.
i dont know what is the steering column wire but on the D3 connect, it look like the previous owner of the car cut a remove a wire ( i circled it in red), and i dont know if the white wire sold where the no.2 is , was connected on the D3 Connector.
I dont know what is no.3 black box either. here's what written on the top of that black box.
[IMG][/IMG]
I alos took a picture of where the black box wires are going, but i can't see where they end up.
[IMG][/IMG]
I tried the cruise control switch on the road but i didnt work. The horn's working so i dont think its the cruise control stalk connector.
Can you guys help me out on this please.
thanks you !
masterpipo1 is offline   Reply With Quote
Old 07-25-2015, 02:57 PM   #2
masterpipo1
Hi there,
i'm doing a DIY Cruise Control install, im at the step to run to ECM A21 conector pin 40 to the D3 Connector. My problem is dont really know wheres my D3 is located. Here's a picture of my panel .
I think it's the number one 1., but it dont look like the same as in the tutorial.
There's a wire at no.2 , i dont know what this for, i a saw a black box no.3 also. I dont know if it's the previous owner who wiring this.
Can you help me out , thanks you. !
Old 07-25-2015, 05:24 PM   #3
masterpipo1
Hi there,
im doing an DIY Cruise Control installation on my Yaris 2007 Sedan (w/o power) automatic.
Im in the step that a i've to wire ECM A21 Connector 41 pin to the D3 Connector. The problem is i can't find my D3 connector.
Here's a photo of my control panel :
and a closer one :
i think it the no.1 but i'm not quite sure, cause in the tutorial, it's says that i've to look at a black wire, but i dont see any black wire alone.
I've install the cruise control stalk, i went on the road to try the cruise control but it didnt work. My horn's working so i guess the steering wheel connector is okay.
On number 2. in the picture, there's a white coming out from a bunch of wire directly connected (solder) to a yellow wire, i dont know if this is why it doesn't work. And on the no1 connected, i've circle a spot , there's a pin there but i dont know if it's that white wire that has been caught by the previous owner...
and that yellow wire is connected to a black box (no.3 on the picture) , and i dont know what this black box for. Here's what you can see on the top of that black box.
and here's where those wires goes. I dont know where they end up.
Can you help me out on this ?
Thanks a lot !
Old 07-27-2015, 08:05 PM   #4
masterpipo1
Hi there,
and a closer one :
Thanks a lot !
Old 07-31-2015, 11:17 PM   #5
ttpmurphy
Drives: White 2011 Toyota Yaris Sedan
Bought the parts from CTScott for a 2011 toyota yaris sedan, power package, automatic. Parts arrived very fast. Worked great! To clarify the guide, the only thing you need for my same car configuration is the control stalk, wire harness (connects cruise control and horn to rest of car), and 2 screws. No need for the D3 stuff like the guide says.
Pics: https://www.dropbox.com/sc/4jufdp0gb...I0EfMPWuFQ-vta
ttpmurphy is offline   Reply With Quote
Old 08-01-2015, 07:05 AM   #6
Correct - For a 2011 Sedan with power you do not need to make the D3 connections as they will already be complete.
Old 08-01-2015, 07:08 AM   #7
masterpipo1 - Those are the same pictures (and for some reason you posted them three times) as what you PMed me. As I told you in the PM you are looking in the wrong place for connector D3. Again, as I stated in the PM - Look at my cruise control DIY for simple instructions on how to remove the lower steering column cover to access D3: http://www.yarisworld.com/forums/showthread.php?t=33750
Also, I don't know what that floating relay is for in your pictures, but the twisted bare wire is not a safe thing to have under your dash.
Old 09-16-2015, 06:15 PM   #8
428CobraJet
Drives: '09 Yaris 3dr, 13 F150rcsb 5.0
Scott...i sent you a pm
You are what you drive.
428CobraJet is offline   Reply With Quote
Old 09-25-2015, 06:49 AM   #9
metalshark
MetalShark
Drives: 2008 Yaris LB
Hi Scott. I installed the Rostra cruise on my 2008 Yaris. I have a 2012 automatic Yaris now. I have a stalk for it. Has anyone done a 2012 yet.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
Old 09-25-2015, 10:46 AM   #10
Yes. Same OEM stalk is used for 2012 as for 2008. Other than the different release of the airbag, there is no difference for 2012 from 09-11. I have the parts required if you are interested.
Old 05-30-2016, 03:44 PM   #11
Mikeyh
Drives: Yaris 2014
Cruise Control Installed!
Scott,
Thanks for the cruise control kit for my 2014 Yaris L. Just as you said, it was easy to install, really plug and play. Took about 20 mins. and the wiring you included for stalk and horn wire made connections simple.
If I can do it anyone can!
Anita (Mikey's wifey)
Mikeyh is offline   Reply With Quote
Old 08-11-2017, 10:49 PM   #12
laobo
Drives: yaris sedan 2011
Originally Posted by Mikeyh View Post
Scott,
Dear Friend.
can you show me, pin of teminal ECM to connect from Swith CCS?
Im a yaris sedan 2014, but i not found pin ECM ( ECU) from my car. OR have you got this Diagram
Thanks!
laobo is offline   Reply With Quote
Old 10-29-2015, 10:19 PM   #13
thomascuba
Drives: Wife's Red Yaris 2007 AT 5D
Dear CTScott;
I would like to install the CC on my wife's 2007 Yaris Base A/T (Hatchback).
Do you still have OEM parts available?
What parts do I need and how much will it cost me? I will prefer not to drill holes on the wheel cover.
Thanks!
thomascuba is offline   Reply With Quote
Old 10-30-2015, 05:31 AM   #14
Originally Posted by thomascuba View Post
Dear CTScott;
Thanks!
Yes. PM sent.
Old 11-11-2015, 08:02 PM   #15
thomascuba
Wiring Missing
Dear CTScott;
I have sent you a PM. I will go ahead and install the CC. But I need to purchase some wires from you.
Thanks Thomascuba.
Old 11-11-2015, 08:16 PM   #16
thomascuba
Missing Wires and Pictures of the Stalk I Got from Friend
Hi CTScott;
Here are the pictures of the Stalk I got.
Thanks, Thomascuba
Old 11-14-2015, 02:33 PM   #17
soldout
soldout's Avatar
Drives: 2010 Blazing Blue 3 Door LB
The cruise control light comes on my dash but I cant get it to activate. 2010 LB 5spd MT power package so I alreadt had the clutch switch wiring.
15' - Crosstrek Hybrid ~ Plasma
10' - Yaris 3 Dr LB ~ The Boom Box
06' - RSX Type S ~ H.S. Dream Car
95' - Delsol VTEC ~ The Racecar
12' - Burgman 400 ~ Garage Queen
09' - Agility 125 ~ 80mpg Daily Rider
09' - Metropolitan ~ Weee
14' - Ecosmart Metro ~ Razor
soldout is offline   Reply With Quote
Old 11-14-2015, 09:59 PM   #18
Did you actually install the clutch switch and is it properly adjusted, where it is fully pressed when the clutch pedal is not touched?
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
