Old 03-27-2013, 07:59 PM   #1
AlphaFox78
Drives: 07 Yaris Hatch
scott, your mailbox is full
AlphaFox78 is offline   Reply With Quote
Old 03-27-2013, 08:02 PM   #2
Sorry about that - I just cleaned it up.
Old 03-31-2013, 02:01 AM   #3
Sum1Kool
Here for the Ride...
Drives: 2010 Yaris 2-door Polar White
Do you still have one if these? Do you have the CC clutch switch?
Thank you.
Sum1Kool is offline   Reply With Quote
Old 04-11-2013, 04:19 PM   #4
joech
Drives: E71
Re: Cruise control
I got the oem cruise stalk, pins and clutch switch from Scott. The parts got here so fast that I didn't have a chance to read the cruise DIY carefully. BTW Scott is great to deal with and he always willing to help if you run into any issue.
Install took about 2 1/2 hours and half the time was spent fishing the wires through the firewall. I ended up cutting a piece of coat hanger in order to fish the clutch switch wire above the clutch pedal. I also removed the battery since I couldn't figure out where the wire would come out. Once the wires got through the firewall the rest of the install was pretty straight forward. I did have a bit of a problem getting one of the pins into the D3 connector. But once the pins are properly in place, I went out for a quick drive and the cruise works like a charm.
Thanks again Scott.
Joe
joech is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 01:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
