Old 11-15-2015, 08:03 AM   #1
soldout
soldout's Avatar
Drives: 2010 Blazing Blue 3 Door LB
Yes, the switch wiring was taped up under the dash right above where the switch mounts. Im going to try and re adjust the switch but Im pretty sure the button is fully depressed when my foot is not on the clutch.
15' - Crosstrek Hybrid ~ Plasma
10' - Yaris 3 Dr LB ~ The Boom Box
06' - RSX Type S ~ H.S. Dream Car
95' - Delsol VTEC ~ The Racecar
12' - Burgman 400 ~ Garage Queen
09' - Agility 125 ~ 80mpg Daily Rider
09' - Metropolitan ~ Weee
14' - Ecosmart Metro ~ Razor
soldout is offline   Reply With Quote
Old 11-15-2015, 09:49 AM   #2
I don't recall having sold you the kit, so you may want to check to make sure that the clutch switch is correct (there are two types that operate in the opposite way of each other).
Old 11-17-2015, 12:24 PM   #3
Eduardo_mty
To install Cruise control on 2016 yaris sedan automatic transmission, i only need
846330821 Cruise control stalk
84633-02020 Cruise control wire
90080-15079 screws
Eduardo_mty is offline   Reply With Quote
Old 11-17-2015, 06:37 PM   #4
90080-15079 screws
Correct
Old 11-18-2015, 10:31 AM   #5
Eduardo_mty
Thank you
Old 11-24-2015, 01:30 AM   #6
Tweete
Drives: Manual YRX 2009
Sorry if this has already been posted about but I seem to be reading a lot of conflicting information.
Can anyone help me?
I Live in Australia (right hand drive) and currently own a 2009 YRX Manual Hatch.
It has steering wheel audio controls.
would anyone please be able to tell me what my options are for cruise control?
Im a 25yr old female not so down with messing with electronic components however i want to look at my options before paying a bomb for someone to install an aftermarket kit for me.
Thanks in advance!
Tweete is offline   Reply With Quote
Old 02-06-2016, 05:41 PM   #7
adubtawa
Drives: 2008 Toyota Yaris 4DR
So the Toyota Yaris 2008 does not have the indicator on the instrument cluster for the engagement of Cruise Control? Is there any way to add this/upgrade the instrument cluster?
adubtawa is offline   Reply With Quote
Old 02-06-2016, 11:02 PM   #8
Only via my indicator module for 06-08 Yaris.
Old 02-07-2016, 09:37 AM   #9
adubtawa
What about if you change the instrument panel to an 09?
Old 02-07-2016, 09:41 AM   #10
No. The ECM for the 06-08 does not support the CAN message to the cluster to turn it on.
Old 04-21-2016, 02:29 PM   #11
Hanu91
Drives: yaris 2013
Hello!
I have manual yaris 2013 with 1.4 diesel engine. What parts do I need for the cruise to get it work?
Thanks
Hanu91 is offline   Reply With Quote
Old 04-21-2016, 07:38 PM   #12
Originally Posted by Hanu91 View Post
Hello!
Thanks
For the diesel, your only option is an aftermarket complete system.
Old 05-25-2016, 07:42 PM   #13
ScarabEpic22
Drives: 07 Toyota Yaris Base
Lots of good info here, thanks for having it as a resource CTScott! I've learned a lot reading through the threads about adding OEM cruise.
I'd like to purchase a wiring kit and indicator from you for my 07 LB AT, tried sending you a PM but looks like there's a minimum post requirement. Sent you a PM, if duplicate then I apologize in advance.
~Erik~
ScarabEpic22 is offline   Reply With Quote
Old 05-25-2016, 08:12 PM   #14
Go it and replied.
Old 06-09-2016, 04:20 PM   #15
signatureseries
Newbie
Drives: 2008 Yaris 3 door
Cruise Control Kit 08 Liftback (3door) Manual
I am looking for a Cruise Control Kit 08 for a Liftback (3door) Manual. I am open to either style (stock or switch). I am new to the forum so i don't believe it will let me send a PM. Do you have anything available?
Go it and replied.
The 34 page PDF file below is a complete DIY for installing OEM Cruise Control on a 2006 to 2011 Yaris.
This will only work for US/Canda/Puerto Rico Yaris, as Yaris from all other areas lack the built-in ECM programming for Cruise Control. Vehicles from other areas must use an aftermarket cruise control system.
Any procedure that requires 34 pages of documentation may seem intimidating, but this installation is really not difficult. I tried to add as much detail as possible to clarify the parts where people who have installed cruise control have had questions.
This guide is broken up in to seven sections encompassing the following:
Section 1: OEM Cruise Control Stalk Installation.
Section 2: Steering Column Connector D3 Pin Installation
Section 3: ECM Connector A21 Pin Installation
Section 4: Connecting the ECM Pin to the Steering Column Pin Through the Firewall
Section 5: Cruise Control Clutch Switch Installation
Section 6: Optional Cruise Control Indicator Module Installation
Section 7: Verifying Operation
http://tinyurl.com/CruiseDIY
signatureseries is offline   Reply With Quote
Old 06-17-2016, 12:59 PM   #16
maral01
Drives: 2007 Yaris Sedan
Hi, new here and just wanted to say thank you to CTScott for this awesome DIY! Installed it in my 09 liftback within an hour and it is working flawlessly. Pulled the parts from a 08 Yaris at the junk yard and, believe it or not, it had that same DIY done to it by the previous owner! Not bad at all, especially since it only cost me 6$!
maral01 is offline   Reply With Quote
Old 06-22-2016, 02:10 PM   #17
jra
Drives: 2015 yaris L
Would a 2015 five door L automatic U.S. Yaris only need the stalk and wiring to plug in to clock spring and horn? If so do you have parts for this?
jra is offline   Reply With Quote
Old 06-22-2016, 03:22 PM   #18
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The Series 3 cruise control installaion is very easy. See http://www.yarisworld.com/forums/showthread.php?t=37205 for details.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
