Does anyone have a backup of this PDF??? After 8 years of ownership I'm fed up of no cruise control
Drives: 2005 Subaru Forester Join Date: Sep 2016
![]() Drives: Toyota MR2 Join Date: May 2021
Does anyone have the pdf for installing this cruise control by chance?
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
Yes. It's about 10 Megabytes. I have put in on Google Drive here
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
Jithin
Drives: Yaris Sedan 2008 Join Date: May 2021
Dear TScott
Any idea cruise control work in Yaris 2008 DCC Yaris Sedan. Hoping your valuable reply. |
i would be highly suspect if it didnt work and i say this as ive been thru the toyota cross referance part number catalog and basicly the same part is used for everything toyota from around 2004/05 till at the very least 2011 with some exceptions running significatly longer and some running shorter..specificaly design changes
Jithin
Thank you sh0rtlife. I have received all the necessary parts. I will give it a try. :)
Does anyone have the part number for the wires we run down the column to the ECM by chance?
Trying to get CC working on a cousins car before she drives across the country with it. |
Drives: Toyota yaris 07 Join Date: Dec 2022
How can i get this cruise control guide for toyota yaris
the link in the post above yours is still good...
i know with an auto running the coastal range it will downshift and handle it just fine..with a manual your kinda on your own there as to wen to downshift and pop out of cruise
![]() Drives: Yaris 2014 GCC LHD 4AT Join Date: May 2023
Hello there,
can anyone help me with the Aftermarket kit for Yaris 2014 GCC - Cruise control? I cant find something useful on the internet myself. as I discover from this forum, GCC versions are not supporting OEM CC. any help would be much-appreciated Folks. For the reference NCP151L-CEPRKV MHFBW9F36F50027xx 2NZFE 1300CC 16-VALVE DOHC EFI |
![]() Drives: '09 Yaris 3dr HB 5sp Join Date: Aug 2009
I have a 2009 Yaris 2 door hatchback with a 5-speed trans. It has factory installed cruise control and 332,000 miles on the odometer. The cruise control recently stopped working. I've tried to activate the CC however the yellow CC light in the instrument cluster does not illuminate, nor will the CC operate. Hoping the culprit was a blown fuse I inspected all fuses - all seem fine. Then, hoping it was the CC stalk (hoped that the switch wore-out) I replaced the stalk with a brand new OEM stalk #84632-08021 Speed Control Switch. The CC still doesn't operate. I checked the original stalk with a multi-meter and the original stalk has continuous power while the stalk button is kept pressed in, but as soon as I remove all pressure off the button continuous power is disconnected. I assume that's how the on/off button in the stalk is supposed to operate(?).
I'd really like to get the CC operational again. What should be next course of action? I suspect that even if either CC disengage switch on the clutch and brake pedals are faulty, the CC indicator light on the instrument cluster would still light up. Is there a relay that powers the CC? Again, the yellow CC indicator light on the center instrument cluster does not illuminate. Other than the CC not being functional, everything else works flawlessly. Bad relay? Bad ECM? Or?...... Any advice that you may provide to restore my CC is greatly appreciated.
"Never argue with an idiot. They drag you down to their level, then beat you with experience." |
#14 |
10-1 odds are its your snail AKA spiral cable, its actualy one of the hardest wearing parts on a car as your basicly bending wires back n forth every time you turn the wheel
9-10 times when a FACTORY CC fails it can be traced to 1 of 2 things, a bad spiral cable or a bad brake switch..and before you go and check if your brake lights work..remember that it has a secondary set of wires on the switch SPECIFIC to the cruise and not part of the brake lights yet the first thing anyone replaces is the cruise stalk thinking its that....belive it or not ive yet to find one dead that wasnt physically visually damaged on the outside...fun side note is that said switch sometimes replacing it with other bad parts will give a false positive and youll have working cruise for a single use...its because you got lucky...i chased that demon earlier this year on an XB..intermitent CC working..was a combo of the spiral AND the brake switch both were intermitently bad |
#15 |
Drives: 2008 Yaris Sedan Join Date: Jul 2024
Hey guys, I got the kit today and installed the CC in a 2008 Yaris (no cruise light)...fast forward and I can't seem to get it to work. Did some troubleshooting over all connections (Pins are fully seated), checked the ground and the connection at the ECM all seem fine. When checking the voltage at D3 pin1 I have 13.3V, hold down the on/off switch and still 13.3V (not going to 0V). Could it be possible that the offshore Amazon stalk is bad out of the box? Any thoughts?
Thanks in advance |
#16 | |
![]() Drives: 2007 Yaris 3dr Join Date: Oct 2024
I am having the same issue, but a 2007 3dr manual. I have all oem parts but cc not working, and same voltage issue when depressing the on/off switch. |
#17 |
#18 |
![]() Drives: 08 hatchback Join Date: May 2022
Does anyone have a link for the instructions? I can't seem to get this one to work. Thanks! In very interested in doing this!
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
