need help with amp and sub brands.....
would like to upgrade from my pioneer amp and 2x 10" alphasonik subs....
currently installed are 4 pioneer tweeters with 4 infinity kappa perfect and a pioneer p3200bt hu.....would like some recommendations...and price range is not above $300? thanks guys
silly yaris....octane 93 r for kids!!! |
Do you want an amp for the sub only, or an amp to run everything?
If it's just for the sub, I would get a Pioneer mono amp + a 12" sub + ported box, look in Sonic Electronics, all this would be for less than $300
. CLA 250, 4MATIC Last edited by derickveliz2; 02-25-2011 at 04:30 PM. |
What's the reason you want to trade out ? Is it old, not loud enough, or just have a few extra bucks and want something new.
Which alphasonics do you have the bottom line ones ? mid or the mack daddy top of the line one's http://www.alphasonikinc.com/subwoofers.html Reason i ask is the 600 and 800 look pretty beefy.
Never mind, )o:
. CLA 250, 4MATIC |
#5 | |
http://www.alphasonikinc.com/venclosures.html i have the dual 10" running an old pioneer 700... i want more solid and powerful sound...
Dude to be honest, I would just try a bigger amp on them, i bet you weren't even hitting half the RMS. (get the model number of your pioneer and we can look that up ) I have been running the Hifonics Brutus Line and have been happy with there stuff. You're asking for Opinions so here's mine
This is what i have and i'm pushing two 12 inch kicker comps with no problem @ 1 Ohm They have an ebay, but these are the guys i ordered two amps from and were pretty good .. http://www.vminnovations.com/product...Amplifier.html ![]() # Type: Mono Block # 1-Ohm Power Rating 1x1200 # 2-Ohm Power Rating 1x900 # 4-Ohm Power Rating 1x450 # Turn-On Delay/ Mute # Frequency Response @-3dB: 20-250Hz # Damping Factor: >250 # Signal To Noise Ratio: > 95 dB # THD + Noise: < 0.1% # Variable Input Level Control (RCA/Unbalanced): 0.2V - 9V # Variable Input Level Control (Mini DIN Balanced): 0.4V - 18V # Input Impedance: 47k Ohm # Input Impedance: 20k Ohm # Power and Specific Diagnostics LEDs # Protection DC, Short Circuit, Overload # Power Supply - All MOSFET: Full PWM # Power Output Circuit Type: Ultra-Fi MOSFET # Variable Phase Shift # Phase Change in Degrees: 0-+180 # Variable Low-Pass 24 dB Octave: 35Hz - 250Hz # Variable Subsonic Filter: 15Hz - 35Hz # Bass EQ: 0-+18 dB # Balanced Inputs # RCA Inputs # RCA Line Outputs # Remote Bass Module Included # Gold Plated Power Terminal Blocks: 4 GA # Dimensions : 11.42" x 9.45" x 2.52"
that can be the case.....imma try upgrading the amp and see if theres a difference...=]
btw anyone know how the infinity basslinks perform?
***** these r what i have in the trunk***** http://www.vminnovations.com/product...nclosure_.html
Give Me Resonance
The basslink is more of a "Bass Filler" than anything, it was my very first "system".
![]() (3) 12" Alpine Type R Subs/Hifonics BXi1208D Hifonics ZXi6.5c / 2006 Kicker ZX350.4 Knu Fleks 1/0 Wiring & In Big 3 Optima Yellow Top Battery/Iraggi HO Alternator Alpine CDA-105, KCA-420i/KCA-121b/KCE-400BT PG TLD22 8V Line Driver |
![]() ![]() Drives: 2007 Yaris RS HB Join Date: May 2007
If you can find one (I'm sure you can), pick up an Alpine PDX 1.600 mono amp. They are compact, run cool, are cheap as they're being phased out for a replacement, and can push a 12" Type R sub like you would not believe.
The next most important investment you will make is in a good sub box or enclosure. Don't go too cheap - minimum .75" MDF. Yes, it's extra weight in the car but if you are asking these questions, I assume you give a rat's a** about your bass. Good luck |
if u check the link...thats exactly what it looks like in the trunk....still looking at amps
boydstir
i was very happy with all my arc audio products maybe you can look into them
Roadrunner Jr.
^If I wasn't on a home audio kick right now, I'd be messing with some Arc SE4200's right now...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
boydstir
like to use a few myself i have looked at them just know it would not stop there more money i would have to spend to handle the horse power
