Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 05-02-2011, 08:35 AM   #1873
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Ok thanks sa mga feedbacks. about sa level ng coolant, ok pa naman, baka nga kailangan ng i-flush yung dati since nahaluan ko siya ng distilled water before (posible kaya?).
rye7jen is offline   Reply With Quote
Old 05-02-2011, 08:49 AM   #1874
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up
Originally Posted by syntax View Post
rye na check mo na ba ang coollant level mo? automatic na mag on ung fan para sa radiator, kapag nag iinit sya, ganun din si shadow kapag naka idle ( observed it already 3 times dati) 1 year na ang flint micas natin, time to flush and refill ng collant. i think normal lang un, paki correct lang po if i'm wrong salamat
kung i-drain mo rin lang ung coolant mo, i advise na bumili ka rin ng radiator flush(available @ saco). Flush the radiator and refill the coolant. Either ung Pre-mix Toyota coolant or AC-Delco..Hinde yung kulay green na nabibili sa gas station ng 15 rial.
HiH
ricepower is offline   Reply With Quote
Old 05-02-2011, 09:05 AM   #1875
syntax
syntax's Avatar
@ rye malamang nga na kailangan na i flush ang coolant, since nahaluan mo na ng distilled water yan before, available ang toyota pre-mix ( fenk color)at 45SR ata, hindi ko na tanda. maganda rin un sinabi ni ricepower na coolant flush,( hindi ko lang try). pero that does not mean hindi na mag On ang fan if mainit na temp ng engine.
@ ricepower ano ung green coolant na un? nakikita ko kasi sa mga hilux pickups namin sa work na un ang ginagamit.
Old 05-02-2011, 09:10 AM   #1876
armando
pilyo
armando's Avatar
Drives: blue yaris y 2009
picepower ano kaya ang maganda sa radiator para sa kabayo ko ang dumi na ng tubig?
advise pre salamat
armando is offline   Reply With Quote
Old 05-02-2011, 09:17 AM   #1877
marble_bearing
marble_bearing's Avatar
Drives: 2008 yaris y silver
malamang... kasi sa pagkakaalam ko kailangan ang mix ratio nya is 50% distilled H2o and 50% coolant. singa matabang lay timplada to kwada.
marble_bearing is offline   Reply With Quote
Old 05-02-2011, 10:11 AM   #1878
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@syntax/ricepower, thanks sa tips, might try that coolant flush pag sweldo na. Alam ko si joni nagflush na rin ng coolant niya.
@marble, matabang la cguro katon unkakapoy la.
Old 05-02-2011, 10:17 AM   #1879
marble_bearing
hwag lng sadiki ha kasi distilled din yun?
naani agmo nacontrol ta abwek lay luganan mo...
Old 05-02-2011, 11:02 AM   #1880
syntax
syntax's Avatar
advise pre salamat
pilyo suggestion lang po,since old school pa ang kabayo mo, start mo ng palinis muna ang radiator, baka meron tayong kilala ng nag ooverhaul nyan sa sinaiya.then saka mo topped up ng coolant.
post ka naman ng close up pics ng engine bay mo.
Old 05-02-2011, 02:05 PM   #1881
ricepower
ricepower's Avatar
isang galon na green liquid ung kulay mga 10~15 rial ang price saudi made
Old 05-02-2011, 02:14 PM   #1882
ricepower
ricepower's Avatar
kaya mo yan iflush ma-isa kaysa bayaran mo ung radiator shop at ganun din ang process na gagawin using radiator flush..
Better check the instruction provided by the radiator flush..
Ung akin nun is the ff:
*drain the coolant
*put fresh water and mix with the radiator flush - check the ratio
*start and rev the engine for 5 minutes..cool the engine and drain the radiator
*put fresh water
*put new coolant preferably pre-mix(kulay fenk)
HiH
Old 05-02-2011, 02:30 PM   #1883
ricepower
ricepower's Avatar
tama si sintaks, dalhin mo yan sa radiator shop for overhaul baka marami ng barado na tubes..nag-ooverheat ba?
huwag mong i-flush magi-isa or gamitan ng radiator flush dyan sa tabi baka di mo na maitakbo after..Ung corolla ko nun na 10yrs old..walang leak yung radiator Nung i-flush ko at gumamit ako ng radiator flush/cleaner..nagsimulang ng mag-leak, yun pala kalawang na ang bumabara sa mga joints Napabili tuloy ako ng saudi made na radiator Sr350 - good for 1.5 year
Old 05-02-2011, 02:36 PM   #1884
rosco
rosco's Avatar
Drives: YaRis ka!--Y?2011
@pilyo jan sa likuran ng umalhamam...marami naglilinis ng radiator...80 sr yung sa hyundai ko,,,baka sayo mga 120...as in lilinisin talaga....yung mag papa flush ka nagawa ko na rin dati yun 40sr....yung green na 10sr..wag nayun ilagay mo ordinaryo lang yun..may pink pa nga nun e...mas ok bilin mo yung sa toyota 40 sr jan sa umalhamam ,,nagtanong na kami ni mike....
rosco is offline   Reply With Quote
Old 05-02-2011, 03:29 PM   #1885
ubospawis
ubospawis's Avatar
Drives: Flint Mica 2010
ang pagkakaalam ko somewhere sa radiator system meron valve na bubukas lang pag tumaas temperature, yung mazda namin dati ganito naging sira nag oover-heat sya kasi sira or me kalawang na yung sensor nya kaya pinalitan then ok na.
ubospawis is offline   Reply With Quote
Old 05-02-2011, 05:40 PM   #1886
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
@rye, di pako nag-FLUSH ng coolant ko, nagdag-dag lang ako last tym. Remember sa kamsa2x, nagaalok ako kung sino may gus2 at sasalinan ko. kulay pula sya original from toyota.
jonimac is offline   Reply With Quote
Old 05-02-2011, 07:22 PM   #1887
syntax
syntax's Avatar
pre eto ung switch na kapag nasa certain temp ay nag cclose ang circuit para mag turn on ang radiator fan,
Old 05-02-2011, 07:32 PM   #1888
syntax
syntax's Avatar
eto ba ung 5SR per refill or top up wahahaahhaha
pre kulay fenk ata un
Old 05-03-2011, 03:13 AM   #1889
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Oo yan nga yung sabi mo dati, akala ko ng nag-flush ka na ng coolant mo.. any future plans? Sabihan mo lang ako.
Old 05-03-2011, 03:14 AM   #1890
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Hahaha! mairap la man.
