#127 |
![]() Drives: Yaris 2010, sedan Join Date: Dec 2010
Where in Japan is the Yaris produced?
Up through 2010, all Yaris/Vitz hatchbacks were produced at Takaoka plant and the Nagakusa plant of Toyota industries, while the Yaris/Belta sedans were produced at Iwate plant of Kanto Auto Works, a Toyota affiliate. SOURCE:http://www.supplierbusiness.com/uplo...ota_sample.pdf Starting January 2011, all Yari meant for export to US and Europe began to be produced at the new Ohira plant in Miyagi Prefecture (source:http://www.houseofjapan.com/auto-mot...t-export-batch). **The Miyagi plant is currently not at 100% production capacity because of the earthquake (source:http://www.google.com/hostednews/ap/...ab3bae869dbc73). |
#128 | |
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
#129 |
There are guides about this if you search around. Long story short, you can either get a spare buckle and plug it in there, use a resistor to trick the sensor, or get lucky and ask someone at your local dealership to disable it using a scantool.
#130 | |
![]() Drives: 2010 Toyota Yaris YR, 5 door H Join Date: Feb 2011
Ohhhhhh! I was flicking through my trip/OBD meter the other day and saw thoes funny dash looking lines and was wandering wtf that was |
#131 | |
My Box and Her Egg
Drives: 05' Scion xB / 08' Yaris 3dr Join Date: Sep 2006
#132 |
![]() ![]() ![]() Drives: 07 YARIS HATCH 5 DOOR Join Date: Apr 2007
it beeps 70 times before it get quiet....and usually 1 gallon of milk is not enough but 2 will make it beep! Ohh and a crate full of quarts of paint as well...!!
#133 | |
My favorite post:
- Cabin filters are under $20 at Kragen. - 2008 Yaris uses the same high-beam bulbs as a 2008 Prius - The rear wheels don't need alignments- just the front. and stock suspension isn't very adjustable anyway. - Half a quart of Marvel Mystery Oil can be added to a full crank case - With concerns of a hydroplaning incident I've moved up to 50k mile 185/65/15 from Firestone (meant for a Prius in wet weather) with no problems... w/ regular hard driving and no rubbing on bounces with max turn. I checked ;) - With the seat folded down flat the car sleeps 4 midgets sideways in the back. 3 in sleeping bags and 2 if you can't find the fitted kind in their size - The cigarette lighter won't work with the key in OFF - I'm about the add a police horn to a buttin next to the emergency light switch. - LED day time running headlights can be mounted in the fog light cups without removing them. But you still have to figure out wiring lol - I have cheap pop off hubcaps that stick out from the tires. I use silver Hammered spray paint after sanding to fix the scratches and it looks cooler and cooler with every coat. Some bastard better not steal them - Aftermarket window tinting looks checkered with polarized glasses on - The front windows including the little corner glass is already factory tinted a little bit. Like %8 or somthing. - It's hard to find your Yaris in a crowded parking lot and you've forgotten exactly where you parked because it was hiding behind that SUV all this time - I get 32mpg because I average 80mph and I'm fine with that - Ive run out with randoms for now |
#134 |
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
^The high-beam bulb IS the low-beam bulb. It's a dual filament H4 (9003) bulb. . . I can't see the Prius using the same bulb if it has dedicated high-beams (especially if it has HID low-beams).
The best modification you can make is between the steering wheel and driver's seat. |
#135 | |
edit: They both take the 9003 |
#136 |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
Actually it now occurs to me (looking at that video) that as easy as it was to remove the part you moded, I think you could leave it unmoded and simply remove it whenever you need to change your wiper blade...
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
#137 |
Only Happy When it Rains
glad i wasn't the only one who thought that.
Colin Chapman disciple |
#138 |
Pull out the 7.5 amp fuse bottom row third from the left to shut off the AC in winter.
It runs whenever you put defrost on.
#139 |
![]() ![]() ![]() Drives: 2007 Liftback Join Date: Mar 2012
If you have power locks, the car will not let you lock the doors if the car is off and the key is in the ignition.
#140 |
![]() ![]() ![]() Drives: 07 Toyota Yaris Join Date: Feb 2012
if you turn the key twice to lock or unlock your car it also unlocks or locks ur trunk :o
Angry Bird Crew #1 ![]() ![]() |
#141 |
![]() ![]() Drives: 2011 yaris Join Date: Mar 2012
There is an interdementional vortex located under the driver seat on the hatchback into which all things dropped with the right hand fall. It is located in a slit in the carpet just in front of the jack. You have to remove the jack and hunt by feel to attempt to retrieve anything there. But once there it is probably gone.
#142 | |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
#143 | |||
![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
Where did you find that? |
#144 |
![]() ![]() Drives: yaris Join Date: Nov 2011
Do not stick lighters in the ac vents on top of the radio
they do explode no matter how much shit people talk about the yaris its still best fun for the price in my eyes if you dont have a rear sway bar your missing out for long term movement of certian items a quick screwdriver to the side door panel handle pops of and allows for long term secrete stash that can easily be gotten to if need be in case of quick consumption {put alittle change in it so it makes alittle noise and covers up missing screw back rear seat was easier to take out than i thought change your battery every 2 half years if you drive alot you cant imagine how much power you get back from a new battery. front cup holders can be stuck closed with quarterz dont let your friends know. all in all the yaris is a fun little car and can say im thankful for it but wish i coulda had it in rear wheel drive. |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Interesting Info on the Yaris from AU | mikeukrainetz | General Yaris / Vitz Discussion | 3 | 11-24-2006 09:18 PM |
