Old 05-11-2011, 05:27 PM   #1
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Which fuel do YOU use
And why? I figured this thread has been made but whatever.
91 Octane Premium for me no other crap added.
Old 05-11-2011, 05:30 PM   #2
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
BE PREPARED to be flamed....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 05-11-2011, 06:12 PM   #3
.Kevin.
I ain't even mad
.Kevin.'s Avatar
For remaking the thread? New members do register quite often atm it seems.
For using Premium? Lol, gas prices don't effect me.
Old 05-11-2011, 06:33 PM   #4
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
It's not that
Originally Posted by sw07gt
Old 05-11-2011, 06:52 PM   #5
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Oh crap.
Old 05-11-2011, 07:59 PM   #6
AppleJacks716
Drives: 2010 5 Door
Not sure why you would use premium, Toyota doesn't call for it. I either stop at BP or Kwik Trip and use regular.
AppleJacks716 is offline   Reply With Quote
Old 05-11-2011, 08:22 PM   #7
2007yariz
Drives: Yaris sedan
I use cheapest regular fuel i can find, why would u use premium?
2007yariz is offline   Reply With Quote
Old 05-11-2011, 08:52 PM   #8
.Kevin.
I ain't even mad
.Kevin.'s Avatar
I just use it because I know it is 100 percent gasoline, it bugs me that the other gas has the other corn crap in it. It feels like the vehicle burns the premium quicker but thats about it.
Old 05-11-2011, 09:19 PM   #9
thepartsmancometh
Drives: '08 LB, '07 WRX
around here all gas is 10% ethanol (corn crap). In response to the question, we run regular in the Yaris (Shell if possible), and I run Shell V-Power in the WRX (and nothing else if I can help it)
thepartsmancometh is offline   Reply With Quote
Old 05-11-2011, 09:40 PM   #10
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Shell gas any good? I heard chevrons techron runs well, I'm one of those people who think premium is best no matter what lol.
Have you noticed the wrx will burn quality fuel quicker than ethanol fuel aswell?
Old 05-12-2011, 10:25 AM   #11
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
I use regular 87 10% ethanol (CT). Premium won't do anything extra for you. My fussiness is that I only use top tier gas which is either Shell or Mobil in my area. I also heard that Chevron is the best but it's not available here.
rick996 is offline   Reply With Quote
Old 05-14-2011, 11:09 AM   #12
thepartsmancometh
All of our premium here is 10% ethanol so its the all the same. There is ONE sation I can by non-mixed prem from, but its a ton of money (like $.25 more per gallon)
Old 05-11-2011, 10:19 PM   #13
severous01
ethanol burns at a 50% less ratio than gasoline. but, it will not detonate in the chamber. so, you're only 95% efficient running any gasoline other than 100% in the US.
second...the rating of octane is not how efficient it is but the burn rate or detonation prevention of the gasoline being used. 87 octane is 87% less likely to detonate at a specific compression than 91 octane which is 91% less likely to detonate. 91 octane burns slower allowing for higher compression or more advanced spark....hence the higher octane rating of performance cars and such. it has NOTHING to do with fuel economy...and actually 93 octane is cheaper to produce than 87.
Old 05-11-2011, 10:35 PM   #14
dingbat
Drives: '10 3D Liftback
Lower octane burns faster and makes more torque. High perf. engines use higher octane because they have to in order to prevent pre-detonation of the charge. They are still running the lowest octane they can get away with. If you use higher octane than you need, the charge burns slower, so more of it is still burning on the exhaust stroke = more strain on the engine, less power at the wheels, and more of your charge wasted burning in the exhaust manifold.
dingbat is offline   Reply With Quote
Old 05-12-2011, 10:43 AM   #15
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I think you logic is a little flawed. What if I'm using 110 octane race gas? It's 110% less likely to pre-detonate?
Old 05-12-2011, 12:36 PM   #16
rick996
rick996's Avatar
No, It can be compressed 110% before it detonates by compression. 87 octane can be compressed only 87% before it detonates by compression.
Ethanol has less BTUs (energy) per gallon than gas so it's less efficient .
Here's a chart of energy values for different gas formulations: http://en.wikipedia.org/wiki/Gasoline_gallon_equivalent
Old 05-12-2011, 09:05 PM   #17
severous01
yes that's it.
Old 05-14-2011, 05:36 PM   #18
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
LOL.. i was thinking the same thing
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 04:54 PM
"5 Driving Myths That Cost You Money" PETERPOOP Fuel Economy Forum 10 05-24-2011 11:20 PM
