Old 07-31-2011, 03:34 PM   #1
^ Good to hear. If you took any pics, we could sure use them!
Old 07-31-2011, 05:14 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Sorry - I'm not one to take pics when I do installs - slows me down too much
I'm curious about those two washers/shims you included...we're they for the bracket mounting bolts? I didn't end up using them and the bracket bolts didn't seem to have any problem going in all the way with the new bracket.
Old 07-31-2011, 06:54 PM   #3
The TRD kit includes two washers. Did the stock bracket use any washers?
They might be to accomodate the difference in thickness between the two brackets?
Old 07-31-2011, 10:12 PM   #4
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
I too am having a lot of trouble with the bracket. I was probably fooling around with it for about 3 hours and never got the stock bracket unbolted, or the shifter cables out of the stock bracket. Which do you do first? Undo the bracket or take the cables out? I still haven't installed the SSK or the bracket yet, since I was to put in the bracket first then put in the SSK. If anyone can post pics, you would be my hero. XD
The good news is I was able to install the shifter bushings for the in cabin and engine bay. Though, those snap rings are bloody hard to do.
Black_griffin6 is offline   Reply With Quote
Old 07-31-2011, 09:44 PM   #5
Altitude
Altitude's Avatar
Yeah, the stock bracket bolts already had washers. I figured it was to adjust for the difference in bracket thickness but it doesn't really seem to need them.
Old 07-31-2011, 11:06 PM   #6
Altitude
Altitude's Avatar
Take the shift cables out of the bracket before unbolting the bracket. You'll have much clearer access to the bracket bolts that way. Also, unbolt the silver wiring harness bracket from the shift cable bracket first too. Aw hell... here's a brief step by step:
- Remove air filter box. (10mm)
- Remove battery.
- Remove battery tray bracket (12mm) (also, unclip as many of the wiring harnesses that you can at this point)
- Remove the pins holding the cables to the shift levers and pull the cables off (careful with the washers)
- Remove clips holding the shifter cables in the bracket. (See below)
- Remove shifter cables from bracket. Push them back towards the firewall until the collar clears the rear of the bracket. Then move them out of the way.
- Remove silver wiring harness bracket from the cable bracket. (12mm)
- Remove the two bolts holding on the bracket (14mm)
- Reverse process.
For the cable clips:
Use a flat head screwdriver - you can wedge it between the exposed cable collar that the bracket slips into and the "L" of the clip itself. Pry, twist do whatever you can to push them up. If you get them up enough you should be able to stick the screwdriver into the gap you just created and pop them out.
Old 07-31-2011, 11:24 PM   #7
Black_griffin6
Okay, that makes much more sense now. Yeah, I saw the silver wiring bracket behind the cable bracket, and I couldn't fit anything behind it to get to the bolts.
I wish these came with instructions. The shifter bushings were pretty self-explanatory, but the SSK not so much. I must be being very blonde today.
I'll probably try it again in the morning, and if I have any luck, i'll post pics to do a DYI for those who were just as clueless as me.
Old 08-01-2011, 11:12 AM   #8
Here are the instructions.
http://www.microimageonline.com/downloads/PTR46.pdf
Old 08-01-2011, 11:42 AM   #9
Black_griffin6
Thank you very much! This should help a bunch! I was actually looking for these all last night but I couldn't find them.
Old 08-01-2011, 07:12 PM   #10
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
So the instructions say to access the bracket bolts from underneath the car. Has anyone tried that yet? If so, is it any easier, and do you still need to remove the entire battery tray to get the cables loose from the bracket?
BTW, thanks for the install sheet Garm :)
goliath1812 is offline   Reply With Quote
Old 08-01-2011, 10:59 PM   #11
Altitude
Altitude's Avatar
The picture in that PDF is taken from under and behind the engine, though I don't think it's necessary to get at it from underneath. Removing the battery tray gives plenty of room to work on it from above. If you go from underneath I would say you can leave the tray in place.
With the tray removed, it was easy to get a standard socket wrench back there with plenty of room to ratchet (as long as the cables are removed first.)
Old 08-02-2011, 09:09 PM   #12
Black_griffin6
I got it installed! I have yet to try it out though.
Old 08-04-2011, 12:32 PM   #13
SAV912
Pirate Yaaaaris
SAV912's Avatar
Just received mine two seconds ago. DAMN, Garm does not fuck around when it comes to selling things!! Ordered Sunday, got it today. Tracker says he shipped it out Monday morning. That is service!
I'm thrilled. My Redline fluid should be arriving UPS today as well so while I take a crack at the bracket and shifter, hopefully it shows up so I can do the fluid change as well.
Will report back with feedback.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 08-04-2011, 03:04 PM   #14
SAV912
Pirate Yaaaaris
SAV912's Avatar
Went outside about half an hour after post above, and just finished. It wasn't an easy install, but not mind boggling either. I printed the TRD directions that Garm posted earlier and while it was helpful as far as tools, the pictures seemed not much of good. They might be pictures of an xD or from an angle that I can't figure out.
Some pointers:
-The battery cable harness is a bitch to keep out of the way so I ziptied it out of the way until I was finished.
-The silver cable bracket that holds some of the battery wires was easily far and away the biggest pain in the ass of the whole install. The short shifter was a breeze and getting to the back of the bracket to change it was relatively easy once I got the damn useless silver cable bracket out of the way.
-I grabbed an extension bar and put an 18mm socket on the end of it and fit that socket over the handle of my breaker bar in order to get more leverage. Somebody short like me would find this very useful since I was already leaning into the engine bay. It also required less pressure to crack the bolts on the back of the bracket this way. Highly recommended for those of you having difficulties getting the bolts to crack. Once they are, it's a breeze.
-Use plenty of lithium grease or liquid wrench to crack the bolts on the bracket itself and to help get the U plates out that are on the shift cables.
-To remove the shift cable U plates, instead of prying at them with a screwdriver (I didn't want to bend them), I grabbed a huge pair of Channelock pliers and clamped on the little lip that they have and wiggled side to side while pulling up. They slid right out really easy after a few futile attempts at prying them up with a flathead.
Impressions:
-I've only been up and down the street with it for now and I still haven't changed the fluid to Redline yet, but THIS. IS. AWESOME. Fore and aft is tight as a virgin now, and it actually enables me to shift with my armrest down now. When I would shift into 4th without the kit, my hand would go almost under the armrest thus having to move the armrest out of the way when in busy traffic.
-About the only negative is the large gap between side to side movement as opposed to fore and aft. I also keep using more pressure going into 3rd and 5th because I'm used to having to push it a bit since the throws were so long. I suppose these are things that I will get used to over time, but overall I am very pleased so far.
Many beers to Garm and Micro Image for this product!!
-C
Georgia Bulldogs!
Old 08-04-2011, 03:04 PM   #15
^ Nice and thanks! Feedback and reviews are welcomed!
My understanding is that the short shift kit only shortens fore and aft movement, not side-to-side, as a "true" short shifter would. Glad you like the improvement!
Did you do the fluid too? That will further smooth out your shift feel.
Old 08-04-2011, 03:29 PM   #16
SAV912
Pirate Yaaaaris
SAV912's Avatar
The short shift kit only does fore and aft, you're right. You'd have to put another bracket on the other cable to decrease side to side movement, but I am impressed all the same.
And this is without the fluid yet as it still hasn't arrived. I am faster than UPS going through my neighborhood because the tracker said it was out for delievery at 9 this morning. They had a four hour head start, come on UPS!! Get it together!!
-C
Georgia Bulldogs!
Old 08-05-2011, 05:14 AM   #17
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
I am still waiting for mine
buti still you Garm
Old 08-04-2011, 03:07 PM   #18
SAV912
Pirate Yaaaaris
SAV912's Avatar
Hah, the man himself posts as I'm writing up my prelim review. Thanks again, Garm. This is a fantastic must-have IMO.
-C
Georgia Bulldogs!
TWM Shift Knob SALE Until July 15th! TWM Performance Sponsors Classifieds Area 6 10-30-2009 12:46 PM
NEW GROUP BUY: NST Short Shift Kit (NonStopTuning) NonStopTuning NonStopTuning 245 08-28-2007 03:53 PM
short shift: NST or TRD? cali yaris Performance Modifications 21 07-07-2007 03:38 PM
Feb Shift Knob Sale From TWM! TWM Performance Sponsors Classifieds Area 2 02-18-2007 10:15 PM
Having Trouble with TWM Short Shift Install. Need Help xfatefailsx07 Performance Modifications 3 10-10-2006 01:38 AM
