Old 05-24-2011, 03:02 PM   #11
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Yes I'm late posting.... I have been busy with lots of works out on going project and this is finally the last mod since there isn't any other space available now LOL!
Summer special tune.... Idividual Twin Radiator setup. The aftermarket rad is fitted after the turbo line in order to prevent unwanted heat from the turbo affecting engine temperature... I was seeing 90C and over with the fan on. Also I installed another fan on the front which is visible on the picture as an add on!
I also installed the Torque damper with lots of custom work to make it fit and also an exhaust motor that cuts the exhaust from the middle. Next thing up dyno although the engine is pretty quick with only 12psi boost. I am almost sure it is above 220Bhp now .... hope to make it up till 300Bhp at 16psi!
Will post pics and vids on the dyno next up!
Parmas is offline   Reply With Quote
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
