Old 06-13-2011, 09:40 PM   #11
Originally Posted by hayden View Post
I'm trying to test the wire right at the stalk, but I think I'm maybe having trouble finding a ground for the negative pokey thing. Do you have suggestions of a ground available near the steering wheel?
I removed all my plastic connectors and just wrapped the ends of wires around each other, put a little solder, and duct taped it. I'm thinking maybe it's the D3 connector but wasn't able to remember how to "unclamp" it.
And it turns out, the extra wire I bought is this thick solid type (think barbed wire with rubber coating) rather than the typical frayed stuff you see in electronics - that doesn't matter does it?
Any bare metal under the dash will make a good ground.
The only potential issue with solid instead of stranded wire is flexibility. Solid wire can't be flexed too much or it will break.
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
