Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 06-14-2011, 08:14 AM   #10
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol rosco sinubukan ko ung filter kagabi kahit wala pa ung clamp (clip) tinakbo ko ok naman, napansin ko lang kapag nag shift ka ng gear at di mo pa naabot ung pinaka peak nya nasasakal nga sya pero pag naabot na ang peak saka ka mag shift swabeng-swabe ang hatak, sa tingin ko un ang nagyari kay gosu.. kung baga sa stock kapag nag shift ka from low to high at wala pa sa peak aalog ang makina na parang hirap.. sa tingin ko si gosu di pa nya naabot ung peak nag change na sya ng gear..
tol rosco, advice mo lang ako if nakuha mo na ung clamp
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
