Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
turbo timer
just picked up a blitz fatt dc 3,
has anyone hooked one of these up to an automatic trans car? is there a switch to set up the timer rather then the hand brake? or what wires are the ones to tap in the steering column? i know the 2008 yaris just can not find anything for an 02 echo. thanks, Steve |
is your turbo water cooled?
Awesome!
not yet.
with my wrx the owners manual even says to idle the car for a few minutes. its water cooled. |
Check out this thread on the MI forum. It was info for a person that was wiring up a remote starter, but it details the ignition switch wire functions. Rather than using a manual switch, you could use the normally closed contacts of a relay to trigger the timer and wire the coil of the relay to the ignition switched power. That way when you kill the engine the timer will automatically come on.
http://www.microimageonline.com/foru...aris-Echo-2005
Awesome!
ok, so i wired it up today, i have 6 wires coming off my ignition switch.
i did 1 and 4, turbo timer works, im missing 1 wire to connect. when the key comes out the sterio rad fan and lights all go out. baisicly trying to figure out what other wires to tap into. 1 Battery Constant 12v+ Positive Wire (+): White/red Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness 2 Starter Positive Wire (+): Black Starter Positive Wire Location: Ignition Switch Harness 3 Ignition Positive Wire (+): Black/Yellow Ignition Positive Wire Location: Ignition Switch Harness 4 Second Ignition Positive Wire (+): Black/Red Second Ignition Positive Wire Location: Ignition Switch Harness, See Diagram 5 Accessory Positive Wire (+): White/Blue Accessory Positive Wire Location: Ignition Switch Harness |
You need the ACC wire, which is white/light blue wire.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| HKS Turbo Timer | Nas_RS | Cosmetic Modifications (Exterior/Interior) | 8 | 10-23-2009 07:39 AM |
| Turbo Project Yaris TS 1.8L | CASTREX | Yaris TS Talk | 40 | 08-21-2009 10:24 AM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
