Try unlocking the door from the inside with the OEM manual door switch. There was incorrect info floating around for quite a while on which wire to connect to for the door unlocking when installing keyless entry or remote start. If the wrong one is used, when you lock the drivers door using the manual inside lock, you can not get it to unlock again with the remote until you first unlock it from the inside. It sounds crazy, but just before I bought my Yaris, a woman on here from Florida had the issue, and then when mine came in and I installed my remote starter, I saw the same issue and figured out the correct wiring (which is in my remote start wiring DIY).
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| I lost my master keyless entry key, need suggestions.... | Frankd1 | DIY / Maintenance / Service | 19 | 12-01-2010 11:13 PM |
| keyless entry? / security? | mem | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 10-22-2008 01:29 AM |
| Aftermarket Keyless Entry - How does it affect the Warranty? | aerock19 | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 09-07-2007 02:11 PM |
| I want keyless entry!!! | Lillydot | General Yaris / Vitz Discussion | 7 | 03-20-2007 10:46 PM |
