#19 |
![]() Drives: 2010 Liftback Join Date: Apr 2011
I hear ya. I trust Toyota and know they make quality products. I just wanna know why its doing what its doing.
#20 | |
#21 | ||
Only Happy When it Rains
And yes, i am almost positive none of the boosted guys have lowered compression.
Colin Chapman disciple |
#22 |
^ Garm and Parmas are the only ones.
I actually only run 89 now with no issues. It's incredibly unlikely the noise is actually pre-detonation. |
#23 |
Well I haven't heard any pinging sounds since switching to 93. Would there be anything else that would make a pinging like sound that would improve by switching to a higher octane fuel? I'm wondering if the ethanol is having an affect on the octane rating?
#24 |
ethanol does have an effect on the octane rating, it makes it higher.
#25 |
#26 |
Bringing this thread back to the top. Still trying to find some answers to a previously asked question earlier in the thread. For those of you who are running on 87 with no pinging, is there ethanol blended in?
#27 |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
100% E10 use since new, no pinging on 87 octane under any circumstances.
R2 |
#28 |
Crazy Oil Sniffer
Also, sg11 you are correct there is less energy in the ethanol so ethanol blends contain slightly less energy. Many here report mileage losses when they had to switch over to E10.
R2 |
#29 |
Local Sh*t Disturber
Drives: 2009 Yaris LB Join Date: Aug 2009
Pinging in a stock yaris... hahaha.
You think your Yaris is low and fitted LOLzzzzz |
#30 |
#31 |
#32 |
yea.. i just dont see a stock new 2010 yaris pinging.. unless u can take it to a dealer and have them verify the noise and do some investigating.. I dont think u really have a problem
#33 |
Based on what you said, and I guess based on the fact that I have 3k miles left on my warranty, I was wondering if I should take it in to Toyota to see why I'm pinging... Is this something they'll chalk up as just what gas station I fill at, or will they actually do some tests? And last but not least, is a pinging problem something that a warranty would repair?
#34 |
^^Disregard. Just called Toyota. Says he has to do tests to establish the cause, which could take several hours. Additionally, he wasn't sure if Toyota would honor said causes under the warranty. There's no way of knowing until he finds the cause, and submits it to Toyota warranty center for approval. If approved, customer pays nothing. If denied, customer gets charged $107.00 for the diagnosis.
Pretty risky. In the meantime, he recommended getting gas only at BP or Shell for at least two full tank cycles. If pinging stops, great. If it persists, bring it in to the dealership.
#35 |
Yep. sounds like a dealership thing.. Also, see if you can get them to pull up a newer yaris and compare the sounds with the service writer. If you can get the service writer to confirm thier is a difference in noise, then you have a better chance of the mechanic to do proper tests instead of just saying "working as disigned", "no problem found", or "normal for this model".
#36 |
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
| Pinging noise coming from the front right | hachi-roku_fan | DIY / Maintenance / Service | 3 | 01-24-2011 04:41 PM |
| Knocking / Pinging | TDaniel | DIY / Maintenance / Service | 11 | 04-08-2010 06:12 PM |
| Pinging belt when wet or cold | steveh74 | Europe (continental) | 0 | 08-22-2009 05:50 AM |
