Old 07-19-2011, 10:22 AM   #55
^ What kind of problems? Bolts won't come loose? Can't get to them?
Provide some detail, I'm sure everyone will try to help.
Old 07-19-2011, 09:02 PM   #56
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
I have no idea what bolt to loosen
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 07-19-2011, 09:10 PM   #57
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
You need to remove these two bolts. The easiest way to reach them is to remove your air intake and your battery. You won't be able to see them, you'll have to find them with your fingers.
-Type 07 FFL-
My odometer 03/11
Old 07-22-2011, 05:24 PM   #58
Guess what? IT"S HERE!!!!!!!!!!!!!!!!
http://shop.microimageonline.com/Mic...MI-SSK-01Y.htm
Old 07-22-2011, 05:40 PM   #59
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
$49 FOR THE BRACKET EH...*SIGH*.... HOW MUCH TO SHIP TORONTO M1G-1H6.... I SHOULD HAVE JUST WAITED FOR THIS COMBO...ANY DISCOUNT FOR PREV SSK USER OFCOURSE BOUGHT FROM YOU..? JUST CURIOUS GARM?
Old 07-23-2011, 01:25 AM   #60
KSIbucky
KSIbucky's Avatar
I'm going out to my car right now and trying to loosen those bolts with me luck.
P.s. I already to my intake and battery and idk but ill let you know
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 07-23-2011, 02:11 AM   #61
KSIbucky
KSIbucky's Avatar
There is no tool known to man that can reach that. I took out my intake and battery and there is just no way. My car is sitting in my garage now with no battery no linkage and no intake because I needed to post this. Did you cut the bracket that holds those wires that are connected to the bracket that holds the shift cables??? Also how do you get the cables out of the bracket???
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 07-23-2011, 02:51 AM   #62
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Garm do i get 1 as well, PLEASE
Old 07-23-2011, 04:47 AM   #63
solarVitz
solarVitz's Avatar
Drives: 08 Yaris S Liftback
Sweet. Just ordered the bracket plate only coz i already got the SSK. Cant wait til I put this on my car now. Thanks Garm.
Hey Mazilla what part of SD are you from bro? We should meet up so I can feel how your SSK with the bracket feels like. Text me bro...619-618-5302, Noel.
Old 07-23-2011, 04:56 AM   #64
mazilla
advocatus diaboli
mazilla's Avatar
If I recall correctly it was a standard 14MM(could be smaller) socket, it should take all of about 5 minutes to get those two bolts off. The bolt heads are going to be facing away from you, you just reach across the engine and using your fingers find the bolt head then slip the socket over and loosen them, you may need a small length of pipe over the wrench handle for added leverage if the bolts are extremely tight. If it's the cables that are blocking you, remove them from the bracket first(see below).
It should be very easy at that point...
No, I didn't have to cut anything.
This was the hardest part for me, but it still wasn't a big deal. Apply pressure from the bottom(with a flat head screwdriver or something) and slide those two retaining plates up and off of the bracket. The cables will slide up and out afterwards. I ran my retainers across my buffing wheel a few times, that's why they are all shiny. I figured it would help illustrate the process.
I'm sorry this is giving you so much trouble...
-Type 07 FFL-
My odometer 03/11
Old 07-23-2011, 12:33 PM   #65
^ Thanks for the assist Maz....
Old 07-23-2011, 01:07 PM   #66
marcus
toyota
marcus's Avatar
just need the right tools for it and a leverage/breaker bar and turn clockwise if the bolt is behind to loosen the bolt youll be surprise how some people gets that clockwise , counter clockwise mixed up specially in this situation..
Old 07-25-2011, 04:08 AM   #67
KSIbucky
KSIbucky's Avatar
i guess ill try again. Im bringing out all the tools
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 07-29-2011, 01:25 PM   #68
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
I couldn't figure out this bracket as well. I can't seem to get the cables out of the old bracket....
I was planning on doing this, and the cage bushings I got from Garm, ended up only doing the cage bushings today.
goliath1812 is offline   Reply With Quote
Old 07-29-2011, 01:28 PM   #69
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I didn't worry about the bracket for now. I will have more time next weekend (not this weekend) to mess with it. I did like the difference in the short shifter vs stock. I now really wonder how much the bracket helps. I plan to put it on but several people are having a heck of a time with it. if there are any secrets/tips to getting this thing off, I am all ears.
Old 07-29-2011, 02:54 PM   #70
Mazilla had an easy install, as did a couple of other customers so far (not forum members).
When in doubt, consult the Toyota repair manuals, which are published (I think still) on Etimago's site, and maybe on here too.
Old 07-29-2011, 03:32 PM   #71
Lil Abner
Drives: 2009 3dr LB Manual
Cali Yaris, you've got a typo on your sale page:
"This give a smoother shift feel than the short shifter piece alone."
"give" should be "gives"
Old 07-30-2011, 12:11 PM   #72
Yay, one person read it, lol. I'll fix that thanks!
TWM Shift Knob SALE Until July 15th! TWM Performance Sponsors Classifieds Area 6 10-30-2009 12:46 PM
NEW GROUP BUY: NST Short Shift Kit (NonStopTuning) NonStopTuning NonStopTuning 245 08-28-2007 03:53 PM
short shift: NST or TRD? cali yaris Performance Modifications 21 07-07-2007 03:38 PM
Feb Shift Knob Sale From TWM! TWM Performance Sponsors Classifieds Area 2 02-18-2007 10:15 PM
Having Trouble with TWM Short Shift Install. Need Help xfatefailsx07 Performance Modifications 3 10-10-2006 01:38 AM
