Hi, I'm new to the forum and I have been looking at some NST pulley Threads and everyone seems to be happy about them.
So my question is do all the pulleys fit in my Japanese Vitz Rs? I saw people complaining on the alternator pulley does not fit all 1NZ-FE engines and I want to make sure they fit with no trouble as I have a limited budget to spend to the car. Thanks for any help given :) |
I can't say since I've never seen a Vitz RS in person.
The alternator pulley fits with a shim, so if it's needed, all the pulleys do fit with that mod.
An engine bay photo could help?
I hope the photo helps.
![]() Drives: 2007 Vios Join Date: Jul 2010
![]() Need at least a 5mm spacer/washer |
#7 | |
#8 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
I purchased the NST pulley set and had issues on the alternator and xb crank pulley. The water pump pulley fits fine. The alternator pulley needs modification in the inner hole since it's a few mm less than stock. Without modification the pulley don't fit tight to the alternator seating. The Xb crank pulley fits fine to the engine without problems but the belt it's about 1mm wider than the crank pulley area. This caused my belt to bend on the out sides of the pulley which by time could result in a damaged belt. Reducing the outside edges evenly with a torn machine would solve the issue. Been running the pulleys for months now and they are fine this way. If you need pictures to understand more I would do some for your information |
| Tags |
| nst, pulleys, vitz |
| 2010 Vitz RS Modellista Completed Car | Vitz Rs Modellista | Photo-Video-Media Gallery | 38 | 11-18-2014 12:25 PM |
| Vitz Photo in Japan | kimona | Photo-Video-Media Gallery | 18 | 12-10-2010 12:34 PM |
| A German Yaris/Vitz/Echo ;) | we-to-11 | Photo-Video-Media Gallery | 5 | 06-27-2007 08:26 PM |
| HKS Japan Vitz | 03Z33 | Photo-Video-Media Gallery | 9 | 04-06-2007 11:55 AM |
| Interesting Vitz in Japan | eTiMaGo | Performance Modifications | 8 | 03-22-2007 08:31 PM |
