Old 07-22-2011, 01:37 PM   #1
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Yes. You would have to add two 12 volt regulators. One for the ECU-B and one for the MET feed to the cluster.
My gauges sometimes show 15.5-16.5 at the battery, I'd like to stabilize it @ 14 if I can. Could you drop an example link on the part I would need?
Thank you for all the
-Type 07 FFL-
My odometer 03/11
Old 07-22-2011, 01:44 PM   #2
You need to stabilize it low, not high. A regulator doesn't bring the voltage up, it will just take a higher voltage and bring it to a lower stable voltage. The part you want is a simple LM7812 voltage regulator (radio shack usually stocks them). It is a 3 pin device with in, ground and out. Normally you would add two capacitors when using one, but in this case, because you are just regulating a supply that really doesn't need to be regulated you can skip the caps.
gas bar disappearing
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
How to save on $4 a gallon gas this summer fnkngrv Off-topic / Other Cars / Everything else Discussions 1 05-26-2011 08:07 PM
Natural Gas Transportation - Why Not? Kal-El Off-topic / Other Cars / Everything else Discussions 1 03-20-2011 02:12 PM
Economics of Price Gouging and Gas shortages GeneW General Yaris / Vitz Discussion 1 10-31-2008 05:20 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
