Old 07-23-2011, 04:47 PM   #1
Lil Abner
Drives: 2009 3dr LB Manual
Custom Rear Wiper Delay Circuit on Swapped Stalk
Ok, here's my final result. I used the information at this link:
http://www.kpsec.freeuk.com/555timer.htm#astable
I created an on cycle of 0.7 seconds, and an off cycle around 7 seconds. Only 3 wires were used to connect the module: Ignition (+), Ground (White/black on stalk), trigger (Blue on stalk). When the wiper switch engages the rear intermittent position, it feeds a ground to the circuit. The circuit takes that ground signal, and passes it through to the Blue wire for 0.7 seconds, every 7 seconds. Right now, I made the circuit non-adjustable. But it's easy to replace a resistor with a 500K potentiometer.
Bench Layout:
Soldered, before trimming the board:
In car, showing connections (thanks CTScott for pin-out):
And video, proof of concept:
http://www.youtube.com/watch?v=rxSQjWtRIx8
I think I calculated everything correctly, so there shouldn't be any issues in the future. All the parts can be found at Radio Shack. Price, I'm not sure. I buy in bulk, so I don't know what a Radio Shack total would run.
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
Rear wiper function, is this normal? Yaris Dick General Yaris / Vitz Discussion 7 11-08-2006 09:46 AM
