Old 07-25-2011, 02:14 PM   #10
tada
Drives: 2008 Red Yaris
51 Is an issue with the driver's side squib circuit, so basically it is something in the wiring between the SRS ECU and the airbag. The most likely culprit is the spiral cable, so I would start by testing continuity between the squib connectors (with them disconnected) and the D3 connector on the steering column.
I'm now having this same problem on my '08 Hatchback. I'm getting a 3251 code. Could you elaborate a little more on where the squib connectors are, how to disconnect them, and the location of the D3 connector on the steering column? Is there are wiring diagram for this connection? Thanks in advance, Tom.
tada is offline   Reply With Quote
Help! Airbag light issue Astroman DIY / Maintenance / Service 24 05-18-2019 12:35 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 08:20 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
