Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
30A Power Fuse Instrument Panel Location?
So i stuck my head underneath and is the description it shows 30A Power fuse should be next to all the other fuses lines up in a grid. But visually when i look at it, I dont see it anywhere there?
Can someone give me a hint or location of this fuse? My power windows aren't working (the green AUTO illumination on the button for the driver window does not glow when car is turned on) I pulled ECU-B engine bay fuse, the wire inside fuse is not broken. I pulled the ECU-IG fuse underneath the clutch pedal and the wire inside fuse was intact and not broken....The power fuse 30a HAS to be the culprit. My passenger window is halfway down, can't go anywhere without getting it back up |
It is on the face of the under dash fuse panel, just under the two connectors with the black locking mechanism.
Heart Up! Vitz
Okay ill have to look tonigh after work.
Is the black locking mechanism near the pink or cyan colored plastic covers..? |
I think you are looking at the relays. The fusible link looks like this:
The Fit is NO!
Drives: '09 3DR "S"|'87 Caddy Brougham Join Date: Dec 2008
Hope this helps guys, Kioshi asked me to take a look to compare to mine, so i took some pics of mine... sorry, big pics, wanted you to be able to see all the little texts
I circled the fuses that Scott is talking about in the 3rd image in red, I also circled the empty spot where another one of the same fuses could go, but is currently vacant in green. I believe its the bottom left pink fuse on the front of the panel (circled in red) that you need to look at/change. ![]() ![]()
My OTHER car ![]() Please ignore the Ferrari
That's correct - It is the bottom left one. Off the top of my head I was remembering it as being higher than the defroster one, but it isn't
Heart Up! Vitz
Computerlove87 and CTScott, I greatly appreciated your help on that matter.
It was the 30a fuse that had been broken. All is well and i can roll my windows up now. Computerlove87 - the only difference i see on mine vs yours is that your diagram is colored in blue and says FT and mine is colored in pink/red. I appreciate you bending your body to get down there in the tight spot. LOL CTScott - I see the RS model has much more wires than the 3door power windows connector, I am not sure which wire controls the back two windows on the 5 door model? I was wondering if i could pull those wires out of the 3 door connector and rearrange to work with the RS trim w/o the back window buttons not working (in future use those to control the sunroof/moonroof??) |
Heart Up! Vitz
CTScott - Since the RS trims were the cause of the blown fuse....
I was wondering since you have a 5-door and 3-door model, to see which wires control the two front windows in the 3-door and which pins on the 5-door model i would need to connect to, to have the front two windows working? Thanks, If not possible, I'll just deal with the empty two slots found on the rs trim for the 5-door model. |
It's kind of scary that the same connector is used with a completely different pinout. I guess Toyota figures that no one would swap 3 door trim with 5 door.
Heart Up! Vitz
Thank You!
Yeah i was surprised myself...oh well, more compatibility :) Last edited by Kioshi; 08-08-2011 at 10:16 PM. |
#11 | |
Heart Up! Vitz
These connectors are A LOT bigger than the ones for the rear tail lights, so i may be able to w/o removing door panel.
I'll start on it after dinner and report my findings/problems here. |
Heart Up! Vitz
Well i tried and tried on Steve's cut wires in the connector, but i couldn't perfect the technique to take them out......
The tail lights were easy to do.... I will go to Home Depot tomorrow and try to use a wire pin nail to stick in, and lift up with pliers and see if that works better~ |
#14 | |
Heart Up! Vitz
I gave up on it...maybe I'll see if radio shack has something to offer? Onto to the bigger mod now. |
#15 |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
iv used a needle from a sewing kit to take pins out. cant get any smaller than that. Ooh cant wait till next week. i hope i have my mod done by then.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#16 |
Heart Up! Vitz
I'll bring a needle. Show me how its done pro :)
And i may not have my main mod done by then. It may look like a disaster if anything, so dont take any pictures of my car haha. |
#17 |
Drives: Toyota Yaris VVTi Join Date: Mar 2013
fuse box - lock,belt sound
Dear, I see you are really in Toyota Yaris. I have Yaris VVTi,1999 Would you give me any info about fuse box, and where can I find lock and belt sound fuses. Thanks ;)
| kuro-kuro, mga sarisaring katanungan | xtremist | Middle East | 2740 | 01-27-2020 03:36 AM |
| Anyone pulled their power steering fuse? | detroiter | General Yaris / Vitz Discussion | 56 | 08-10-2011 05:15 PM |
| where is the friggin fuse panel? | darkMINI | DIY / Maintenance / Service | 4 | 08-11-2010 03:24 AM |
| Power Window/Lock Panel w/motors | eocintron | Willing to Buy by private party | 4 | 11-23-2009 11:46 PM |
| POWER WINDOW POWER SOURCE IN DOOR PANEL? | mrrock | DIY / Maintenance / Service | 5 | 03-21-2007 06:27 PM |
