I dont wanna start a problem. but most brand new belts, esp aftermarket will stretch given time. You can easily just tighten the belt without using those brackes and using a crowbar or lever of some sort to pull the alt. towards you while you tighten up your #2 bolt.
Your idea is very interesting though. My only problem is over tightening it and ruining your alt bearing for the newbies. And if that 3# bolt isnt of all the way because you can still overtighten it, the vibrations of the motor will shake it off and possible land inbetween a belt and pulley and shred it. Just my 2 cents |
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 02:05 AM |
| Squealing Belt | rossman | DIY / Maintenance / Service | 8 | 01-31-2012 02:58 PM |
| Supercharger Belt Slip Possible fix | quemoto | Forced Induction Forum | 20 | 03-04-2011 03:55 PM |
| 2010 Prius brake problems easy fix. best video ever! | dinamix | Off-topic / Other Cars / Everything else Discussions | 6 | 03-15-2010 12:00 AM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 09:53 PM |
