Correct if you have factory DRLs. If you don't then the tails are the opposite polarity and you have to provide +12V to pin 10 (T1) instead of a ground to 13 (B1).
#2 | |
always toyin'
Can you kindly do one final review of what I'm about to do based on this diagram I created? Many thanks again Scott ![]() * Headlamp control status after low-light is detected by sensor -> Relays switch pin 13 (tail) and 8 (Low) to GND: ![]() -toy
- Procrastinators of the world unite! ...tomorrow. ![]() My Garage.. 'Mild' Drop & Misc..2-DIN GPS/Navi..DIY:Rear Wiper Delay..Ramps/Roll-Ups..Rain Sensing Wipers / Auto-Headlamps |
#3 | |
Perfect.
always toyin'
Besides the sensitivity adjustment for rain/moisture detect in the sensor area, I can't find anything in the manual that mentions about sensitivity adjustment for ambient light unfortunately.
How the Rain Tracker Controls Headlamps Really, really well. The Rain Tracker senses the ambient light level outside the vehicle, and turns on the headlamps when it is dark, or when it is raining. Most US States require you to have your headlamps on when it is raining, and it is simply a good idea. Great -- I will report my results later this week. -toy
always toyin'
Came here to report that the auto headlamp feature works! The same sensor detects both ambient light and rain that automatically triggers the headlights when it gets dark out and/or when it rains.
The system allows you to install 2 switches: 1 to bypass rain sensing (comes with the kit), and another switch you need to buy seperately to bypass the auto headlights and disable these features anytime. Thanks again CTScott! -toy
| ABS and "!" lights are ON again! | onizuka | Canada | 457 | 04-28-2023 09:40 AM |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 03:54 PM |
| Anyone Installed Rain-X Wipers? | M4One | DIY / Maintenance / Service | 35 | 02-12-2010 10:15 AM |
