Old 08-23-2011, 01:22 PM   #5
lAYJAY
Drives: Yaris
Okay, let me see if I understand correctly. In the door there is a plastic connector (with 2 wires) that goes in the factory speaker. So, If I want to use the actual wires, I would need to cut the plastic connector, which will leave me with two wires, attach these wires to the speakers wires. Then I would get the wires that goes in the radio and redirect them to the back (amplifier)? Will that work?
And, the factory wires are much smaller than the one I have to install. Will they power enough and be resistant considering an amplifier will supply the new speakers?
Thanks for the help
lAYJAY is offline   Reply With Quote
install speaker, rear door, wiring
Rear Passenger Area Power Outlet DIY - Sedan fnkngrv DIY / Maintenance / Service 4 04-04-2019 07:03 AM
Rear Speaker size on Sedan? fnkngrv In Car Entertainment + Electronics (audio / video / alarm) 3 07-03-2006 02:39 AM
