![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
Digital temperature control
Where can we get digital heat and A/C & fan control ? the one with the lcd display for temperature control !
Thanks!!!
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
It's possible to make the swap but it takes a lot of parts and money. I'm actually looking into sourcing all the required parts as the top of the line cars here are sold with the digital controls, and will put more information once we have it ;)
But don't expect it to be cheap or easy.
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
^^ what no mention of ECHO_HOR and his swap???
OP: check out microimage if you want to see what one owner did to his car.....
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ Last edited by ROCKLAND TOYOTA; 08-31-2011 at 02:30 PM. |
I created a complete plug and play harness to allow Echo_hrs to install the 'Automatic A/C" system on his car. There is a thread on here and one on MicroImage with the details on what is required. New from Europe the parts would run over $2000, and probably even more new from Japan. Echo bought his used from Japan, and it was still about $1000 for the parts required.
Here's a YouTube video of what I put together for him: http://www.youtube.com/watch?v=qbInNKKEwFc
I wasn't sure if echo_hrs or CTScott wanted to publicize it ;) But yeah, it's one heck of a job :)
What if i dont have the A/C ?
It's going to be much easier and cheaper ?
er... I would think way more expensive and harder as you still need the actual physical AC system (compressor, piping, evaporator, etc)... CTScott can probably give you more details but I have no idea how hard it would be to retrofit!
If you don't have AC, then it would be VERY expensive, as you'd need the complete USDM AC system (minus the control panel and USDM AC ECU) as well as all of the JDM parts.
| Digital Gauges, Auto Climate control, Manu-matic shifter | computerlove87 | Cosmetic Modifications (Exterior/Interior) | 21 | 12-02-2012 11:55 PM |
| FS: Temperature control knobs | Sodium Duck | Items for Sale by private party | 0 | 01-21-2009 01:25 PM |
