Simota SRI rubs driver side headlight
My Simota SRI is such a tight fit that the cone is packed against the driver's side headlight.
I'm wondering if anyone else had this issue and what they did to alleviate it. Yes, I tried the search function but I couldn't find anything relevant. |
bump, nothing?
Pictures would probably help a lot.
The cone is touching the driver's side headlight.
It's not a full connection of the whole cone, just part of it closest to the front of the car.
you're sure everything is pushed together tightly?
Ok, here's a question:
Is it supposed to be a metal to metal contact between the intake and the engine? |
how about a picture of the other end?
I think you might be able to jam that filter on a little bit more? It may just be a tight fit on the sedan; I know these work fine with the liftback. It also doesn't look like there's a problem in terms of function.
It's on a liftback :p and functions great.
I'm just worried about scuffing up the driver's side headlight. I know, shouldn't be a big deal in terms of resale value, but you never know. Next time I'm tooling around in my engine, I'll try to snug things up even more but I thought everything was tight when I put it in. |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
No, I don't think you want the intake pipe to be touching the aluminum throttle body. So you could try to pull that one out a bit. But then loosen up the other connection points and try to push those sections closer together.
It's not touching as it is.
Been a lazy bastard since I got back and haven't done anything with it yet. Then again the game I'm playing right now is down for maintenance. Great time to look like a crackhead and tinker with my car. |
^ LOL
I just went out and tried shoring things up but I don't really have any space left.
Is there any sort of lubricant that I can put on there that would make it slide easier and not mess up the engine or rubber? |
^ silicone spray is fine to use on rubber parts.
#14 |
#15 | |
itll be fine rubbing the headlight...
| Side of headlight reflectors | regal | Cosmetic Modifications (Exterior/Interior) | 7 | 04-13-2009 03:26 PM |
| WTB: Drivers Side Headlight LiftBack | Saggio | Willing to Buy by private party | 7 | 03-10-2009 02:21 PM |
| Driver side foglight trim | gwasabi | Willing to Buy by private party | 3 | 03-03-2009 03:11 AM |
| Replacing driver side mirror? | supernes550 | Cosmetic Modifications (Exterior/Interior) | 4 | 01-26-2009 11:11 AM |
| The Driver Side River | Nutzoids | General Yaris / Vitz Discussion | 7 | 12-14-2006 01:11 AM |
