#19 |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
Rooted and OCed mine. OC is absolutely necessary to play Hulu..well root too. But in the end, i need more of a laptop than what even the docked form can provide. Afterall its still weaker than a netbook. Plus theres an update to the eepad coming very very soon with the new processor.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
#20 |
On a trek to upgrade...
Drives: 2003 Echo Coupe Join Date: Mar 2010
Saving money for it, I still also need to find a way to keep it charging while it is in use.
#21 | |
always toyin'
![]() -toy
- Procrastinators of the world unite! ...tomorrow. ![]() My Garage.. 'Mild' Drop & Misc..2-DIN GPS/Navi..DIY:Rear Wiper Delay..Ramps/Roll-Ups..Rain Sensing Wipers / Auto-Headlamps |
#22 | |
#23 |
always toyin'
^ It's already been researched and proven to work. I have already built my own DIY home adapter for my Eee Pad and works flawless.
http://forum.xda-developers.com/show....php?t=1087321 -toy
#24 |
I'm going to best buy today to look at some stuff. Wish me luck!
#25 |
update?
#26 |
Just picked up an Acer A100 Iconia 7" tablet (Honeycomb 3.2!). Over the next several months I'll be working on getting it installed and writing some custom SW to work with my bluetooth OBDII unit (which means I'll be selling my ScanGaugeII, Ultragauge and possibly my HU.)
The size of this tablet is almost a perfect fit for the OEM radio bezel. Hopefully I can work out an installation that looks super clean. It doesn't have cellular capability (I think the A101 does) but I think I can use my android phone and tether it when needed. Does have GPS, BT and WiFi so all that's good. Not sure if the USB port supports hosting, but I think the dock connector will so I might have to buy a dock and cannibalize it for the port connector. Should be an interesting project and I think this is a better solution (less hassle and less cost) than a carputer which is something I always wanted to install but never had the time. Last edited by Altitude; 09-04-2011 at 02:43 PM. |
#27 |
yep, the advent of (relatively) cheap, powerful tablets is going to make some big changes to in-car entertainment, that's for sure!
#28 | |
Definitely interested in what oBd stuff you'll do, better than Torque?
#29 |
I pretty much scrubbed my earlier attempt at a carpc, and am looking forward to getting a Nook very soon as well. At $180ish it's too good a price to pass up. Heck, at that price it could almost be worth it to get a couple more for the rear seats (if I still had any
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#30 |
Found a decent solution for in car charging. Next step is deciding where the eff I am going to put this damn thing.
#31 |
if I had the fabrication skills, I would get the blank 2-DIN plastic plate that the base models came with instead of a radio, and make some brackets that directly attach to that.
Which tablet did you buy? You should check if there is a desktop dock available for it, that would make for a good base, and keep the tablet easily removable, all you would need is a spring loaded clamp to hold it in place at the top.
#32 |
Looks like finding the right amp is going to be the challenge. Been looking for a *small* 5 channel and they are hard to find. Something along the lines of the pic that Emerge has in one post only with the addition of a sub/5th channel.
Everything I see is huge wattage and for show. I don't care what it looks like. I don't need huge wattage either. I want to hide it, preferably behind the dash. Emerge - Where did you get that pic of the tiny amp? I tried to search for it using the brand and model number on the unit and can't find it. Test Fit: Last edited by Altitude; 09-10-2011 at 07:27 PM. |
#33 |
nice work, get nook in soon
#34 |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
That fits quite nicely!
Altitude, look on eBay. There are a TON of small 2-channel, low power amps out there. They are usually $20-30. I personally have 2 tiny old-school Blaupunkt amps (2x25W) that I always used for my tweeters. I can't remember the site I found that had a ton of them. But here is an example of one I use to own: http://www.crutchfield.com/S-FFyk0Ps...kt-PA2100.html Also remember, there is room under the passenger seat for an amp! |
#35 |
Thanks Lil Abner. Thing is, I already have an amp under the passenger seat for the SW. I think what I'll probably do is get a single DIN HU that has the outputs I need and also has an AUX input so I can hook the tablet up to it. There's room to stash the HU behind the tablet, just need to tie it down.
#36 |
Got my Nook Color installed. The bezel thickness is causing me some mind pain {installed as close to the radio trim as possible, needs some side trim pieces}. The tablet is too tall when laid horizontally. pictures to follow to explain. Tho it looks awesome to have Torque app running there.
I'd like to be able to remove the tablet from the car but right now ibhave to remove the HU trim to do so. It's too wide to just come out of the Double Din bezel ![]() ![]() ![]()
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 Last edited by ezhacker1; 09-17-2011 at 08:04 PM. |
| Dash lights won't work after installing new head unit? | blh4645 | General Yaris / Vitz Discussion | 10 | 04-06-2010 06:17 AM |
| Need help with installing head unit Pioneer AVH-P6850DVD | JCMoon | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 08-31-2007 10:27 AM |
| Req: Head unit suggestions. | xed | In Car Entertainment + Electronics (audio / video / alarm) | 21 | 08-09-2007 07:38 PM |
