Old 09-11-2011, 07:49 PM   #235
str8Yaris
str8Yaris's Avatar
Drives: Yaris Sedan Supercharged
^ he has a fixed pulley and a wastegate so he can adjust boost. see post #228
Ahh now I see..
Blitz S/C @ 9psi
Vegas meet 2011
http://youtu.be/1IEebCmtvP0
str8Yaris is offline   Reply With Quote
Old 09-23-2011, 04:53 AM   #236
sujonol78
Drives: 1nz-fe / MT
Send a message via Yahoo to sujonol78
Originally Posted by revoturbo View Post
yesterday Drag race Indonesia 24may 2009, 1/4 mile 14,5 sec
http://modifikasi.com/showthread.php?t=55387
Yaris 200HP indonesia by ZAGE turbo kit + snow performance
Dastek unichip type Q
dastek turbo module
gizzmo IBC turbo booster
BOV Greedy Type RS
Zage Turbo Kit bolt on
Auto Bahn oil cooller 12 fins
cluth tube TRD
water -methanol Injection "snow performance".. COOL
porting polish
open air filter hks super flow
muffler hks high power
heat sink filter simota
XCS by huricanne ground wire
power ignition X-Power
pivot earth spark
oil cath tank simota
oil cap TRD
radiator cap C-One
ACT heavy duty clutch kit with toyota celica metal clutch pad
fuel injector toyota altis
pertamax plus (Fuel)
best time : 15.4 s ( Sentul Drag race 22-23 november 2008 )
dyno results after retune....
Hp: 202.7 BHP@6000 Rpm
torque : 257.7 nm@4500 Rpm
engine modification by Rev Enginering....( Thank's for: Teddy and Agus)
multimakmurperformance.com
guys, you should really check the specs, no way he could get 200bhp without changing the internals, the oem internals couldn't withstand that kind of boost. You should've seen it on the track, it was so "smokey"
and you should ask him about the turbocharged toyota vios ( 1nz-fe ) that he burnt too
sujonol78 is offline   Reply With Quote
Old 09-24-2011, 12:02 AM   #237
Several members on here are getting 170 whp from the Zage kit. So 200 bhp is not unreasonable at all. And yes, the internals can withstand 8-10 psi (required for that power).
Old 09-26-2011, 01:54 AM   #238
johnny_vitz
Drives: 2005 Toyota Echo
Did they change internals for the newer 1NZ? I thought the blow point was usually 150+whp. I thought blown_xa went through a couple engines @ 150 whp before building anyways?...I'm always nervous on track days with only 130ish whp haha
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 09-26-2011, 08:53 AM   #239
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Maybe for track use you might want to stay at 150whp. But then again i have been running 210whp for a good while now. As many have said tuning is everything.
Yoda is offline   Reply With Quote
Old 09-26-2011, 09:39 AM   #240
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
dead on yoda, dead on
-Derrick-
Old 09-26-2011, 01:55 PM   #241
johnny_vitz
I completely agree with the both of you. I just remember reading through all the threads on scionlife/clubxb about build before you boost, and most guys who had blown an engine were dyno'd/tuned at 140-150whp. But now, more and more yaris have 175+ without issues.
That's why I was curious if anyone knew about any change there might have been to the bottom end with the newer models Either way, i'm jealous of your 210hp
Old 09-26-2011, 03:16 PM   #242
ilikerice
ilikerice's Avatar
good question though, prob best if one of the toyota techs like "rocklandtoyota" or "ctscott" can compare part numbers..
-Derrick-
Old 09-26-2011, 03:52 PM   #243
Who can prove it's the boost and not the tuning?
A couple? He should definitely post up in here so we can learn.
Old 09-26-2011, 07:12 PM   #244
johnny_vitz
Nobody can prove if boost or tuning did it really. I'm just curious
I looked for a while and found this on scionlife
Originally Posted by blown_xa View Post
what vettereddie said... 150whp. Ive tested limit more times then I care to admit.
http://www.scionlife.com/forums/showthread.php?t=200391
I hope he can chime in at some point
Old 02-16-2012, 05:45 PM   #245
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
Garrett boosted Echo Hatch :P Add me if possible. Thanks
maxthehax is offline   Reply With Quote
Old 02-16-2012, 05:51 PM   #246
Jerkratt
Jerkratt's Avatar
Add me. Blitz supercharger since last year
"It hurts more when its wet"
Old 02-22-2012, 07:18 PM   #247
yaris2010RS
yaris2010RS's Avatar
ooooo add me plz :D
Old 02-24-2012, 03:22 AM   #248
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
2007 Yaris Sedan
Custom T28 Turbo 7psi
underdrive crank pulley
15" stock steelies
winterforce tires
AEM F/IC
AEM UEGO Wideband
High Flow Cat
2.5" mandrel bent exhaust
91 octane with STP octane boost
HKS Super Sequential BOV
No video at this time. Will record video after fuel pump is upgraded possibly within next 30-60 days.
Old 09-11-2012, 01:08 PM   #249
Fer
I love my stock
Drives: Yaris TS
Does an ep82 count?
I still have my 2004 yaris TS, and just found out that there are plans to get her turbo this year.
The TS Lifestyle!
Fer is offline   Reply With Quote
Old 10-03-2012, 11:45 AM   #250
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Rockin that Blitz in my sedan now :)
Old 10-03-2012, 12:00 PM   #251
Jerkratt
Jerkratt's Avatar
--UPDATE--
Running the Blitz kit with wire in fuel controller removed still using the switch for throttle position/off. Tuned with the AEM FiC. Tuned by API Tuning
Old 10-03-2012, 12:03 PM   #252
47_MasoN_47
Noticed any difference running the AEM vs the Blitz fuel controller?
Yarisworld Decal -SHOW YOUR YW PRIDE!! Astroman Items for Sale by private party 235 08-21-2019 11:45 AM
The Official "Bambo the Yarisworld Traveler" thread (V2) *MAD DOG* Off-topic / Other Cars / Everything else Discussions 528 06-22-2009 04:58 PM
EBAY Seller Alert for Yarisworld Members redyaris DIY / Maintenance / Service 29 07-02-2007 10:23 PM
HiLEDs discount on High Intensity LEDs for YarisWorld members! Hileds Sponsors Classifieds Area 103 04-06-2007 01:28 PM
Yarisworld Parts List - Work in progress vodkalush General Yaris / Vitz Discussion 5 02-13-2007 07:12 PM
