Old 10-01-2011, 10:34 PM   #12
metalshark
MetalShark
Drives: 2008 Yaris LB
AC function
The ECM controls the cooling fan via a relay (I did not say that it does not have a relay, just that the ECM has complete control over this process). Normally this does happen when the AC is turned on. The AC tells the ECM via CAN bus message that the AC compressor is running (the AC ECU fires the compressor directly, without a relay) and the ECM turns on the fan via the fan relay.
Since the OP's fan and compressor both turn off, my suspicion is that the AC ECU is logging a DTC and shutting down the AC.
If the fan relay is an open loop control line then failure of the fan relay will cause high head pressure at the compressor. Pressures too high or to low will cause the ECM to shut down the compressor clutch for system self protection. Many times the fan relay coil will develop an internal short that causes a cyclical thermal related failure that is harder to diagnose because some times it works, and some times it doesn't just like an ignition coil pack.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C intermittently cold Wildcat DIY / Maintenance / Service 4 08-23-2010 03:21 PM
yaris diesel,heater blows cold air.. cccecider General Yaris / Vitz Discussion 2 02-19-2009 01:25 PM
