#361 |
Section 1, specifically 1.1.1...
#362 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
Yes I know..but I mean...I pull on the whole steering wheel...or only the middle part where there is the toyota emblem ?
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#363 |
You are only removing the airbag (which is the center portion of the steering wheel), unless you wish to drill the lower steering wheel cover off of the car, or are replacing it with a pre-holed one.
#364 |
![]() Drives: Yaris 5DR Join Date: Jul 2011
Just finished installing and works perfectly. Wish the 07s had a cruise light on the dash though. Oh well, thanks for the good DIY Scott.
I was wondering how you managed to feed the clutch switch wires through the firewall. I gave up because of limited space and just fed the wires back through the passenger side grommet. |
#365 | |
#366 |
Drives: 2011 Yaris 4 Dr. Sedan Join Date: Sep 2011
For DIY cruise control
When drilling 1-1/8” opening in the steering wheel trim/cover, I used small square of black winds surfing jacket neoprene (just to cover up guts of the switch) and then used sliced windshield washer hose to finish the edge. What can I say , my wife’s attention to details is admirable.
Ratz --------------------------------------------------- Cleverly disguised as a responsible adult.
#367 | |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
What kind of wire is necessary, I have a radioshack and a homeimprovement store nearby (and a wallyworld,) I don't know if any of them sell durable wiring-- maybe the home improvement store for inwall wiring. Did your radioshack, local parts store actually carry resistors? Any advice from someone who has completed the install is great! Thanks :) |
#368 | |
The clutch switch can be bypassed, but it's pretty easy to forget and touch the clutch while in cruise control mode. For the wire, any stranded 18 to 20 AWG wire is fine. Radioshack will probably have the resistors as part of a multipack. If you want to do the OEM stalk method I have all of the parts (stalk, clutch switch, ECM pin, etc.) on hand and can ship overnight or two day if you need them quickly. Here's the link to my DIY for the OEM stalk method: http://www.yarisworld.com/forums/showthread.php?t=33750
#369 | |
for the jumper, should I just drop in the wire and solder it to the correct locations. I'll probably eventually get the clutch switch but I just want to be able to turn it on and off really, for now. out of curiosity how much is your kit? :) oh yeah, from past experience: does braking automatically disengage the CC (since it is ECU i would say yes)? thanks for the quick reply |
#370 | |
For the temporary clutch switch bypass, you can either solder in a jumper or find a small male spade that will fit tightly into the connector along side of the pin. Kit pricing: CC Stalk with wiring and mounting screws: $40 ECM connector pin: $5 Connector D3 pins: $5 MT CC clutch switch: $15
#371 |
quick question on those momentary switches: I found a few at radioshack but they are low-amp rated (like .5A).. I noticed the referenced digikey switches are around 3 amps. what's the max rated amperage I should shoot for?
i found a few packs of resistors at the local radioshack, but none at 240. looks like i'll be soldering them together to make 240. they're rated at 5% tolerance, if combining them would the tolerance inherently go up? |
#372 | |
For the resistors the tolerance means how far they can be off, so a 100 ohm, 5% can be 95 to 105 ohms. Since it is a plus or minus rating, chaining them together means that they can cancel each other out, or add to the percentage off in either direction. If you have a multimeter, you can measure the actual resistance of each.
#373 | |
#374 |
actually looking back at the wiring for two buttons, one single resistor of 630ohm seems like it would work-- between the two buttons on positive; still not sure about the set-cc pushbutton resistances range though
#375 | |
You can use any value within these ranges: 216 to 264 ohms for one between resume and on/off 351 to 426 ohms for the one between set and resume 819 to 1001 ohms for the one between set and cancel For the two button method, a single resistor 567 to 690 ohms can replace the 240 and 390 ohm resistors. For current rating of the resistors, like the switches, it really doesn't matter, so 1/8 W, 1/4 W, 1/2 W, etc. are all fine.
#376 |
ah ok great, that helps big time in finding a proper resistor. why is it necessary to use the different clutch switch assembly, can the original clutch start-switch assembly be tapped in to?
#377 |
No, they are two different switch functions. The existing one detects that the pedal is fully pressed for starting and the CC one detects the initial press of the clutch pedal.
#378 |
to do this do I need to buy a new terminal pin for the ecm? where can I get this?
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
