Old 10-10-2011, 09:03 AM   #73
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Originally Posted by pimp my yaris View Post
I cant believe I didnt see this thread before. Turbo looks usable, looks like a gt25 knock off. I can tell U one thing for sure. After many months of tunning headaches, there is no way to run a properly tuned car with a mass air flow sensor and a BOV. If U want it to run smooth and never dye out. You need to go stand alone with a manafold pressure sensor or recirculate blow off gases back into the intake. I just installed a hose to recirculate my BOV gases and my car has never run better. I would buy a BOV that you can attach a hose to. Just a sugestion. This project is sure to bring some heavy stress but if you finish it your car will be a lot more fun to drive. Good luck.
You can run a BOV, just run the MAF before the throttle body instead of the turbo inlet tube. It's called a blow through setup. Put BOV anywhere upstream from the sensor (12'' away suggested ). You will get no stalling because the MAF won't know the BOV is open.
This is an example ... one of our kits
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 10-10-2011, 11:18 AM   #74
I put my BOV on the intercooler, Grand Am style.
Old 10-10-2011, 02:07 PM   #75
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
Hmm, pics?
Club SHIFT
Old 10-10-2011, 06:45 PM   #76
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
I bought all the stainless pipes, 02 sensor bungs and a stainless flex joint to make a down pipe. Then I mounted the turbo and manafold and drove the car to a couple of exhaust shops. Until I found one that would work with me. Just make sure your oil feed and return are on. The idea of a pressurized mass air does work with a blow off valve. I just dont know how much that effects tuning. I have never seen a pressurized mass air sensor from the factory. One very important thing. Make sure the oil return line enters the top of the oil pan above the oil level. If it is submerged it will be restricted. I learned the hard way.
Got lots of smoke from the exhaust.
pimp my yaris is offline   Reply With Quote
Old 10-11-2011, 08:10 PM   #77
TickleTimeTim
Free Mustache Rides
got to do a little fitting today. someone please explain what the opening is on the pic of the close up of a pipe and also where i need to run my pipe to turbo. the AC compressor is in the way.
Fixed it, thanks stove
Club SHIFT
Old 10-11-2011, 08:49 PM   #78
TickleTimeTim
Free Mustache Rides
oh and that intercooler that the guy said would fit, ridicutlous...i need a small one
Club SHIFT
Old 10-11-2011, 10:59 PM   #79
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
Unless I'm missing something, the thing in the way is your A/C compressor not your alternator.
Stove is offline   Reply With Quote
Old 10-11-2011, 11:07 PM   #80
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
You really just need to bring your car to a performance shop. All those pipes are universal bends not cut to length. Intercooler looks like it will fit, it helps though if you dont mount it upside down. Crashbeam has to go.
Ptuning.com
Old 10-11-2011, 11:11 PM   #81
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Oh boy by the time you finish this I bet you could have bought a Zage kit! Good luck man, you need to get this baby to a performance shop like Bown xa said!
Old 10-11-2011, 11:15 PM   #82
pimp my yaris
C'est la vie
Ya that intercooler is way overkill. It will cause to much turbo lag with a small turbo. Mine is only 5.5 inches tall. I bought a universal intercooler and pipe kit off ebay. Still needed to buy a second 2.25" pipe kit to finish.
Old 10-12-2011, 09:05 AM   #83
TickleTimeTim
Free Mustache Rides
I'm learning the hard way if you can't tell by the questions I ask and the way I'm doing it all wrong. Yeah, do you remember the vendor you got yours from, pimp. I thought about doing that route. Nobody in town will do this for me. Not even the suggested names on this thread. I figure I wanna learn this anyway, so I just post pics and ask questions, and hope I dont get bashed too badly. Thanks for all advice.
Club SHIFT
Old 10-12-2011, 09:07 AM   #84
TickleTimeTim
Free Mustache Rides
Oh, removed crash beam, didn't know that's what yall had done. Ok, I need another day off.
Club SHIFT
Old 10-12-2011, 09:19 AM   #85
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
most people don't , but I did . It is only designed for 5mph hits anyways.
Ptuning.com
Old 10-12-2011, 01:55 PM   #86
TickleTimeTim
Free Mustache Rides
Is it self explanatory to remove? Or should I do a good bit or forum searching.
Club SHIFT
Old 10-13-2011, 03:31 PM   #87
Focus_Sh1ft
Focus_Sh1ft's Avatar
Don't remove the crash beam, just get a smaller intercooler. That thing is so retardedly large I can't even think of when it would be useful.
Old 10-13-2011, 05:43 PM   #88
pimp my yaris
C'est la vie
Take a look at this. This is the iintercooler and pipe kit I purchased from Ebay. It also came with a BOV that U can recirculate if U want to.
http://www.yarisworld.com/forums/sho...t=29053&page=5
Old 10-14-2011, 02:20 AM   #89
TickleTimeTim
Free Mustache Rides
i see your kit, and i want it, but i didn't see the name of it
Club SHIFT
Old 10-14-2011, 01:08 PM   #90
TickleTimeTim
Free Mustache Rides
Aha, found the kit for about 200. How much piping did you end up using from the second kit? Also, i see the bov it comes with, but do you think mine will do fine? How has your bov held up?
Club SHIFT
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 03:53 PM
