^The thermostat wouldn't affect the heater, the heater bypasses it.
Have a look on the underside of your hood for a pinkish spray line directly above the belts. If there is one, your water pump is shot and you're loosing the coolant through that. For now, top it up and monitor the level. Make sure you top up the rad AND the overflow container to the MAX level. If the coolant is low enough you'll need to idle the motor from cold and top it up. DO NOT open the rad when it's hot. You can be scolded with hot steam or coolant. |
#2 | |
| Tags |
| coolant, heater, overheating, radiator, thermometer |
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 09:04 PM |
| ATX temperature overheating? | yaryarbing | Fuel Economy Forum | 7 | 05-07-2011 10:24 AM |
| 2007 Yaris Door Lock Issue | bhola | General Yaris / Vitz Discussion | 7 | 10-05-2010 01:01 AM |
| heater control box issue | DevilGirl | DIY / Maintenance / Service | 12 | 01-08-2010 04:45 PM |
| CONSUMER REPORTS : MARCH issue reviews '09 YARIS . | gid | General Yaris / Vitz Discussion | 93 | 01-06-2009 05:10 AM |
