Old 05-08-2015, 01:07 PM   #1
kou
Drives: 08 lb
I have the same noise coming from drivers side front. I believe it is the wheel bearing starting to go bad and sticking a little it is annoying but not in a rush to fix.
Old 05-09-2015, 09:59 AM   #2
Kazimodo
Kazimodo's Avatar
Drives: Yaris 2007 3 doors
Thanks Kou , I was thinking the same thing
ANNOYING , tolerable for now , too busy .
Kazimodo is offline   Reply With Quote
Old 07-12-2015, 12:59 AM   #3
bairjo
If they are available...go wth a Timken bearing.
bairjo is offline   Reply With Quote
Old 05-09-2015, 12:50 PM   #4
kou
Drives: 08 lb
I am going to purchase a used spindle then install a new hub and bearing in that so it will be an easy job when I feel the need to change out the bad one.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Installing Rear Wheel Bearing Hub brad4ds Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 07-22-2011 06:34 PM
Front Wheel Bearing Failure craigq DIY / Maintenance / Service 4 08-17-2007 07:26 AM
