rust on paint chips on roof above windshield
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
![]() ![]() ![]() Drives: 2009 5-Door Liftback Join Date: Jun 2011
So, looks like the best way to prevent rust is to keep it clean, I guess. I've been running my car through an automatic touchless car wash in the winter, so it looks like I'll keep doing it. Automatic touchless carwashes are expensive, $10 around where I live for the full wash, including undercarriage. But getting rust cut out and the panel repainted would cost a lot more, so I shouldn't complain. Silly question, but would driving your car during a heavy rainstorm clean out the fender lips? Or would it actually cause more dirt to accumulate?
I haven't gotten any of the corrosion on the wiper arms that people here are talking about. Maybe I'm just lucky. |
#4 | |
Not really ![]() Look in your rear wheel well. In front of the tire is a big flat area that rocks and mud collect on. Easy enough to see and clean off. Now run your fingers along the inside of the fender-lip above the tire. You will feel a small lip and it will probably be packed with road dust. On some cars (hondas etc) you just wipe you finger under there when washing the car an it's fine. These cars the lip is small and pointed up. Mine has seam sealer in it, so toyota obviously thought to keep dirt out, but it is not enough. The mud still collects. My plan is to clean the lip well with a brush and water, heat-gun to make sure there is no moisture left in the lip, then fill the lip completely with 3M exterior seam sealer shaping it so its tapered. Then spray the wheel well with an oil based undercoat. That, combined with washing it properly will hopefully end any rust concerns with the rear fender lip. I am planning on having this car for it's entire service life so may as well spend a little time now to address it. I have a feeling this little bugger is going to run for a looooong time ![]() Going to try toyota for warranty on the wiper arm. If not, I will clean then spray them with some epoxy primer when I spray my other car. Wiper arms are easy enough to repair/replace. Rear fenders not so much. Cheers. |
| New Cars vs. Used Cars | chrisj | Off-topic / Other Cars / Everything else Discussions | 19 | 10-07-2010 10:03 PM |
| CARS & COFFEE Car Show - 2/6/2010 | ozmdd | Southwest | 0 | 02-05-2010 12:33 PM |
| Cars and Coffee Dallas POSTPONED TILL FEB 6 | ozmdd | Southwest | 0 | 01-28-2010 04:00 PM |
| California May Ban Black Cars | MadMax | California | 69 | 12-09-2009 10:44 PM |
| Before Buying Yaris - Some Newbie questions | Gingi | General Yaris / Vitz Discussion | 13 | 09-08-2007 05:28 PM |
