#1 | |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
While what you say may be technically accurate you completely overlook the fact that fuel efficiency techniques bleed into and overlap each other. It is nigh impossible to extricate an intertwined technique from its siblings, so striving towards DFCO usage will invariably lead to more efficient usage of brakes and deceleration and downhill throttle control while simultaneously making the driver more FE-aware in general. If it is easier for folks to understand that whole set of skills simply as DFCO usage please let them be. Please try to look beyond the trees so that you can see the forest. Getting caught up in the minutiae of an easy-to-understand and easy-to-use technique will do no one any good.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
I believe in accuracy, and in correcting misleading and/or erroneous information. What you discovered is that brakes turn kinetic energy into waste heat and that conserving kinetic energy helps fuel economy. DFCO is a relatively minor enhancement to that.
My clarifications in no way reduce the value of the information you have provided. But having a more accurate grounding in *why* it works will allow people to make more effective use of it. That's not "attitude". It's a simple respect for truth. I believe in calling a spade a spade. -Steve |
#3 | |
Audio Junky
It's easy to rack up time in DFCO if you were making sure you were coasting in neutral before you heard of DFCO.... The last stick car I had owned was a 86Jeep Cherokee I had in HS. It didn't have DFCO... so I always popped it into neutral when coasting. |
#4 | |
Regarding relative fuel use between normal idle and 65 mph in neutral, the Yaris uses about 20% less fuel in neutral. Normal idle uses 0.20 GPH, whereas coasting neutral uses 0.16 GPH. So in 2 minutes of DFCO, you are saving a whopping 0.0053 gal (1/187th gal) of gasoline compared to coasting in neutral. Which is about 1/2100th of a tank. Keeping in mind, of course, that it takes longer to get down the hill with the transmission in gear due to that fact that the engine braking slows you down. So the actual savings would be less than that. -Steve |
What?
Valid point, Steve. We're probably seeing most of our gains in MPG simply from changing our driving habits. DFCO is a good excuse to do it, but we wouldn't be using THAT much more fuel if the engine were idling at all times.
Let's say I was driving conservatively and went 400 miles on 10 gallons of gas. (a reasonable assumption for me, I usually do much better than that in city driving) My average speed for this tank of city driving is 30 mph, so total driving time is 13.3 hours. Let's say that instead of clutching in and letting the engine idle, I spend 20% of my driving time coasting in DFCO. How much of a difference is it making? 13.3 hours x 20% = 2.66 hours at .2 gph... call it .5 gallons. 400 miles / 10 gallons = 40 mpg 400 miles / 9.5 gallons = 42.1 mpg Wait... 42.1/40 = 5.2% improvement! So, yeah... the bulk of our improvements (easily 10-20% over EPA without trying hard) come from driving style changes. But, I'd say that there's a solid 3-5% or more to be gained from making good use of the DFCO feature in city driving. And for people who practice the "pulse and glide" technique, DFCO can improve their highway mpg, too. No, it's not magic. No, it's not "new" technology. But, now that people know about it, they have developed repeatable driving techniques to take advantage of it. Footnote: Is it possible to spend 2.6 hours of a tank of gas in DFCO? I think so. Using myself again: My typical trip is maybe 20 miles round trip. If I don't hit at least 20 stops on that trip, I'm stunned. So, for each of those stops, I'm doing a full 20 seconds or so of DFCO coasting. Call it 7 minutes for every 20 miles. 20 of those trips on a 400 mile tank gives us 2:20 just from traffic lights. That's not including the amount of pulse & glide that I do. I'd say for any given mile that I spend cruising at speed, I'm DFCO coasting at least 10 seconds. (if my cruising speed is 45, that's 10 seconds out of every minute and a half, not at all unreasonable) This might only apply to half the miles traveled (the rest of the miles are spent accelerating or decelerating due to stops), so there's 200 miles x 10 seconds each for another 30 minutes of DFCO. I think my estimates here are very conservative for when I'm seriously "hypermiling", and they've added up to 2:50 of DFCO time. While I completely get what you're saying, Steve... you can't deny that DFCO absolutely CAN make a difference in fuel economy for the driver to takes complete advantage of it. And it all goes hand in hand. If you're maximizing your DFCO time, you ARE driving conservatively. |
#6 | |
As mentioned in my previous post, this is about people having an accurate understanding of what is going on. And appealing to the fact that efficient driving practice involves a lot of interacting factors is really irrelevant to that point. Because the benefit specifically attributed to conscious use of DFCO *can* be separated out, and is relatively small in the grand scheme of things. That doesn't make DFCO bad or insignificant. It just defines its place in the landscape better. -Steve |
What?
Brian and I were typing at the same time... and said much the same thing in the end. Brian went on to say a few things that I was thinking, but didn't say because my post was too damned long already. Heh.
I see that you live in Oklahoma, Steve. Please try to expand your horizon enough to realize that not everyone lives in the Great Plain. Many of us, talnlnky included, live in hilly and/or mountainous regions, and in these areas it is not uncommon at all to be in DFCO for extended periods of time.
During my own commute there are instances where I am in fuel cut for as much as 7 miles at a time, for a total of around 20 miles per workday. Considering that commuting represents 90% of each tank, calculate that and then tell me that DFCO doesn't mean anything to FE.
#9 | |
Audio Junky
Some of my best tanks of gas have come from commutes that involved hills/mountains, where I was able to coast A LOT in gear. |
#10 | |
(Yes, I drive *quite* a lot.) Nice try. But you really need to get out more before you counsel me upon "expanding horizons". I probably cover more ground in a month or two than you do in a year. And more varied (and mountainous) ground, at that. So why don't you try addressing the facts I've presented rather than trying to sneak in a personal attack based upon your guess about my driving experience. I have made quite a number of factual points, in previous posts, which you seem set upon ignoring. Look. DFCO is a handy tool in the tool chest. But you have overemphasized it in comparison to some of the other useful tools there. I like seeing 9999 on my Scangauge II as much as anyone. But even over extended DFCO periods, the effect needs to be kept in perspective. Because the Yaris engine easily uses 20 times its idle consumption just as soon as you start ascending the next hill. -Steve Last edited by sbergman27; 03-10-2010 at 08:12 PM. |
Because your "facts" change nothing. At the end of the day everything that you've presented is interesting but completely unnecessary, and contains as much opinion as fact.
I say again, getting caught up in the minutiae helps no one. Let us agree to disagree on the best implementation and/or public understanding of DFCO and move on.
Tell you what. Using 0.16 GPH for coasting in neutral, 0.20 GPH for idle, and 0.0 GPH for DFCO, and ignoring engine braking factors for now... why don't you work out for yourself how much DFCO could realistically be saving you on a per tank basis? I don't really care about the answer. But I think it would benefit you to go through the exercise.
Sorry if you feel I stepped on you toes regarding your "discovery". But the numbers I have presented cut to the very heart of this matter. If you disagree, then please present an alternative model. |
so DFCO is better than coasting in neutral? cause i get 27 mpg right now lol
#14 | |
So it really depends. Judiciously applied, it can help. But the ECU software is designed to do best when you don't try to second guess it. |
Only Happy When it Rains
wow dude you're just being a jerk. This is the real world, not some lab.
Colin Chapman disciple |
![]() Drives: 2008 Polar White Yaris Sedan Join Date: Mar 2010
awesome. i did not know this
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
I appreciate this Forum Thread. I’ve been using DFCO all the time since I read this thread. FE improvements have been incredible. Presently, I’m near making the 50 mpg range. This is a goal of mine to reach, before I use more advanced techniques.
I have a silly question? Does any one know? There is a long mountain grade I drive every day. I let off the gas and use DFCO when I go down it. The long grade starts to level and my vehicle’s RPM drops down to around 1,000 – 1,100 RPM. But, then the grade steepens quickly causing my RPM to go back up to over 1,800. My MPH does drop down when I reach 1,100 RPM, but there are hardly any drivers, so I can do this... Does DFCO kick back in automatically when the RPM goes back over 1,100? Or do you have to give it some gas (accelerator tap) over 1,100 RPM and then let the grade take over again? Is the Yaris ECU software designed to do this automatically? When the RPM gets just below 1,100 RPM and then climbs up again, I do nothing... just coast in the gear till I have to slow down and come to a stop at the bottom of the mountain. Cheers...
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
um,,, i think this is called "coasting" people have been doing it for decades lol i like the special name for it now... DFCO great marketing ploy!
| low gas mileage? | yrsdrgn | General Yaris / Vitz Discussion | 30 | 01-17-2019 03:26 AM |
| Synthetic oil MPG boost since change | Yaris Dick | General Yaris / Vitz Discussion | 29 | 09-15-2007 08:15 PM |
| Increased MPG or HP anyone???? | slvryaris | Performance Modifications | 55 | 05-27-2007 10:49 AM |
| MPG trackers | acrbill | General Yaris / Vitz Discussion | 11 | 01-01-2007 07:34 PM |
