Old 11-07-2011, 04:07 PM   #7
A-Dingo-Ate-My-Baby
Drives: yaris
Not to diss anyone's opinions, but...
Every action has an equal and opposite reaction. And tsunamis are an example of this. Drop a rock in the water and it sends out ripples. The energy contained in those ripples will remain constant under ideal conditions, but will drop over time in any real situation. In order for a 1/4 mile high wave (or even a 100-metre-high wave) to hit the whole East Coast, enough energy must be imparted at the source to create such a wave. I haven't crunched any numbers yet, but I'd be willing to bet (with my life, actually, since I live on a small island on the East Coast) that no one volcano in the Canaries can produce enough power to do this.
You not only have to create the initial wave, but then to send it over 3000 miles, and have it create a mega-wave over 2000 miles of coastline. Assuming the landslide that causes this is over, say 5 miles of coast, then each mile of slide must be able to power a giant wave that will cover 400 miles of coast on the other side.
I call "Improbable" at best, but will look at the numbers.
look at the numbers first plz
the most likely scenario
a catastrophic failure of La Palma west flank, drops 150 to 500 km3 of rock into the sea. Using a geologically reasonable estimate of landslide motion, we model tsunami waves produced by such a collapse. Waves generated by the run-out of a 500 km3 (150 km3) slide block at 100 m/s could transit the entire Atlantic Basin and arrive on the coasts of the Americas with 10-25 f (3-8 m) height.
why does this matter ? it will be the entire east coast where there are ZERO tsunami walls in place.
it is probably not going to happen, or it will slide incrementally and not produce large waves, but
the possibility exists nonetheless and the chance is increased lately due to volcanic activity
the base of the island is 4000 meters below sea level. If that full flank also blows out in a huge eruption
and lateral collapse, similar to Mt St Helens (where the entire side of the volcano slid outward and downhill),
there will be a tsunami far larger than the estimate above. Will is happen ? probably not, but the chance is not zero.
A-Dingo-Ate-My-Baby is offline   Reply With Quote
