Old 12-12-2011, 04:36 PM   #1
benw85
Drives: Yaris 1.4 D4-D
non-locking front passanger door!
Hi All,
Just got a Yaris 1.4 D4-D and really pleased with economy and refined diesel engine. The car is 2004, spec T3. The front passanger door does not lock/unlock with the other three doors when using the remote. It remains independent of everything else. At the moment when my Girlfriend gets in the car I have to get into car and open door manually via interior knob and the same to lock it manually before leaving when locking.
The interior knob on the passenger door does not fully 'pop up' as the others when you unlock with the remote.
Does this indicate a problem with the locking mechanism or actuator, or do they both mean the same thing?
It's not the end of the world but I would like to sort it...
Regards
BW
benw85 is offline   Reply With Quote
Old 12-12-2011, 05:10 PM   #2
The actuator may be bad. You can remove the inner door panel to check the wiring to make sure the connector isn't unlatched. If it's not the wiring, then it is likely the actuator.
Old 12-12-2011, 05:16 PM   #3
benw85
Cheers for the quick reply boss. I will check shortly. Is the 'actuator' the only locking device within the door that can be faulty? i.e, there is no locking motor and actuator?
Regards
BW
Old 12-12-2011, 08:24 PM   #4
Regards
BW
There is just the actuator, which is part of the door lock assembly. The manual lever overrides it by pushing and pulling a cable.
Old 12-13-2011, 02:16 AM   #5
syntax
syntax's Avatar
we already encountered these problems from other members, the cable that is latched into the actuator broke, we just replaced it with other cables.
Old 12-13-2011, 06:41 AM   #6
The OP's problem is the opposite of the broken cable issue. The OP's cable works, but the electric actuator does not.
Old 12-14-2011, 04:03 AM   #7
syntax
syntax's Avatar
oopppssss... my bad...
Old 03-05-2012, 11:15 AM   #8
redglare45
redglare45's Avatar
Drives: 07 Sedan - 5 Speed Manual
I think I have the same problem with the actuator. On mine, I hit the lock on the key-fob, all locks turn to lock, but right away the passenger lock comes back to unlocked, while the other 3 doors remain locked. This also seems to be causing a 30 second alarm arming delay, where as before the alarm would arm after 2 chirps back to back. Now it's chirp....wait 30 seconds...2nd chirp, then the alarm is armed.
redglare45 is offline   Reply With Quote
Annoying driver door rattle Vince87 DIY / Maintenance / Service 5 09-26-2016 11:16 PM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
Replaced door panel fabric with perforated leather to match Clazzio seat covers CTScott Cosmetic Modifications (Exterior/Interior) 13 10-03-2011 11:43 PM
Confused about front door speaker fit. flaystus In Car Entertainment + Electronics (audio / video / alarm) 3 04-15-2011 06:26 PM
Does the 5 door LB have P/W only in front? auxmike General Yaris / Vitz Discussion 4 06-23-2009 11:20 PM
