Old 12-31-2011, 05:49 PM   #11
sqcomp
Roadrunner Jr.
sqcomp's Avatar
On my end, I've removed the glass shells from the trunk and am starting the build up and panel separation process. You saw the pics of the trunk on my FB didn't you?
It looks like I can put two ID8 V3 D4 subs in the glovebox/footwell area and have 1 cube of space with a common chamber setup. This means those little 8"s will feed down to 20 Hz at the 3dB downpoint. Thank gawd for EQ control! 18 Hz notes off 8"s, here I come with no subs in back and a truly complete front stage.
Thank you for your inspiration with the I6SW!
― Thomas Paine
