Old 03-13-2007, 01:09 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
@eTiMaGo:
Thanks for the information! My ScanGauge II hasn't arrived yet (I got in with the group buy on PriusChat so it should be here shortly) so I'm glad someone else is providing hard data.
@Nutzoids:
It sounds like you're making progress, and that's great. :) No, using the friction brakes will not disengage DFCO. The 3 ways you will leave DFCO are:
1) Touching the gas pedal.
2) I don't know the exact RPM yet but if you drop below about 6 MPH in any gear the ECU will start sending fuel.
3) Using the clutch on the MT or using overdrive on the AT.
For example, using just the brakes (no clutch) while engine braking will not affect DFCO at all, and this is how I dump extra speed on short, steeper sections of the downhill parts of my mountain commute.
- Brian
Share the Road
Old 03-13-2007, 01:38 PM   #2
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Good to know!
Nutzoids is offline   Reply With Quote
Old 03-20-2007, 03:17 PM   #3
Nutzoids
Nutzoids's Avatar
Yo BailOut,
So I did a full tank of gas using your DFCO method... and even though there was a big snow storm here are the results!
03/12/07 - 03/19/07
305 Miles on tank... 29.65MPG
Which is on the high side of my MPG, but nothing outstanding... My highest was 31 (Back when I was breaking in my car)
Like I had said earlier... it was more convenient, didn't have to stop at red lights and stop signs!
So yes I can see where it will help, but don’t expect too much… I will continue to do it until my next oil change… but this was the first tank!
low gas mileage? yrsdrgn General Yaris / Vitz Discussion 30 01-17-2019 04:26 AM
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 09:15 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 11:49 AM
MPG trackers acrbill General Yaris / Vitz Discussion 11 01-01-2007 08:34 PM
