![]() Drives: Yaris HB 07 Join Date: Jul 2009
I need help with these parts!
Hey guys,
I need to replace the parts in red on my Yaris: ![]() how can i find them? |
2ZR swap. DO IT! Ask how!
I normally start by looking at villagetoyotaparts.com since they still have diagrams. Once you find the parts in the pictures, get the part numbers and then order them from a parts dealer.
![]() Drives: Toyota Yaris Join Date: Oct 2008
Called a "Belt Moulding"
-Toyota Dealership -Local Bodyshop |
#5 | |
![]() Thank you guys. I have another question: the web shows that there are 2 stock codes for the weatherstrip assy, front door glass: 6821052110-6821052130 for the outer LH, and 6816052110-6816052130 for the outer RH. Both have the same description at the web. http://www.villagetoyotaparts.com/pr...821052110.html http://www.villagetoyotaparts.com/pr...821052130.html How can choose the correct option if both are the same? I have seen the diagram and it is only one piece but with two stock codes for each side. ![]() For the rear doors they show only two codes, for the RH and LH, but i have four ones for the front doors, i'm confused. Sorry for my english, i don't write very well. |
I'm gonna make an assumption and say that LH and RH stand for left hand and right hand. so it would depend on whether you are using it on the driver side or passenger side. the tapers would be different. the description would be the same (I would assume).
I can't see your original post so I am not exactly sure what part you are looking for (my workplace blocks photo hosting sites ie, photobucket and the likes) so I can't be sure which one you want. please check with other users here before making a difinitive choice though. it would make sense that it is what is meant but just because it makes sense doesn't mean it is what is meant. |
I'm clear that LH and RH are left and right hand, the problem is with the parts for the front doors, they have 4 codes: 2 for the RH and 2 for the LH weatherstrip.
I have sent an email to villageToyotaparts sales team and they said me that it depends of the VIN of my Yaris, i have sent the # and the description of my car ('07 HB 5-Door 1.3L M/T) but i don't have answer yet. |
DAT'S RIGHT I GOTz 2
they jus wanna make sure you get the right part
5dr H/B 68160-52110 pass front door outer strip 68180-52100 pass rear door oute strip
Form>Function
discountoyotaparts.com is good as well ive ordered 4 different replacement stock parts from them for much cheaper than I could find elsewhere.
#10 | |
68210-52110 Driver Front 5dr H/B 68210-52130 Driver Front 3dr H/B 68160-52110 Passenger Front 5dr H/B 68160-52130 Passenger Front 3dr H/B
Yep, villagetoyotaparts emailed me today and sent the correct codes for the 5Dr version.
Codes finished in 52130 are for 3Dr version. Thank you guys. Well, i now am looking for the pillars covers some people said me that it is a common vynil moulding, but i don't want to put on my car non-original parts. |
they're called blackout tape
pass frt # 75921-52070 (No#1) pas rear# 75923-52060 (No#2) #75925-52061 (No#3)is for the tape on the pillar between the doors
![]() ![]() Drives: yaris Join Date: Nov 2011
They have awsome customer service if you have anyquestions just have them call you or them. they saved me 200 bucks on a rebuild because i was confused on s model to non s model and woulda had the wrong part
I finally bought the weatherstrips at www.discounttoyotaparts.com, the have better prices than villageToyotaparts.com, i am waiting for the shipping info right now.
Thank you guys |
| 07 YARIS Liftback FOR PARTS | benjomothians | Items for Sale by private party | 12 | 02-07-2012 01:53 AM |
| Aftermarket parts and Factory Warranty in Canada? | jonathanq | Canada | 3 | 07-11-2009 12:17 PM |
| FS: C-One Parts new & used - Socal | 03Z33 | Items for Sale by private party | 90 | 06-03-2009 10:08 AM |
