Old 01-15-2012, 10:45 PM   #1
yo_omar
yo_omar's Avatar
Drives: Yaris Hb 09
some items i have and have questions
ok this is what i have im waiting are on their way the wastegate and the oil lines, gauges. i have the manifold but not in this pics and need a new down pipe . now my questions
1) i need to now where i can find the adapter for the flow meter, or what i can do
2) any one have this turbo its big and i dont know if its going to fit and if the car can charge it. i need to change it for another more small?
3) i dont want to make a hole for the oil lines what else i can do. i have another oil pan so i can use that one for the return line?
4) what else i need i just want 6 psi
TRD Yaris Edition
Official Technician of Toyota & Scion del Oeste Hormigueros
yo_omar is offline   Reply With Quote
Old 01-16-2012, 12:52 PM   #2
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Tu carro is AT?
Originally Posted by sw07gt
Old 01-16-2012, 12:54 PM   #3
yo_omar
yo_omar's Avatar
Drives: Yaris Hb 09
Tu carro is AT?
No manual
TRD Yaris Edition
Old 01-16-2012, 11:01 PM   #4
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Where is the turbo manifold?
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 01-16-2012, 11:52 PM   #5
Old 01-17-2012, 12:38 AM   #6
yo_omar
yo_omar's Avatar
Drives: Yaris Hb 09
I can use this for feed oil and return oil from the turbo without make a hole in the motor?
http://shop.microimageonline.com/Oil...OS-osa-001.htm
TRD Yaris Edition
Old 01-17-2012, 06:50 PM   #7
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I don't read I just look at pictures. Ha
Ptuning.com
Old 01-18-2012, 08:35 PM   #8
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Turbo looks usable and not to big. U will need a lot more intercooler piping. I used two kits from Ebay 2.25in. I also bought a cheap cold air intake to get that mass air sensor adaptor pipe your looking for. Make sure when you tap the oil pan for the turbo oil return line you make it as high as possible. Above the oil level line. It will save U from problems later. Also think about a wide band o2 sensor and piggyback computer for tuning. I used Aem for both. They work well. You will also need to reclock that turbo to get the oil drain on the bottom once its mounted. Good luck. I have many pictures and tips on my thread.
pimp my yaris is offline   Reply With Quote
Old 01-19-2012, 02:08 PM   #9
You'll be tapping the block, not the pan, just for clarity. The Yaris' pan is too shallow to tap into; it's more of a cap for the bottom of the block.
