Old 01-23-2012, 07:04 PM   #7
swidd
Drives: Yaris HB
Ratz, I think you're overreacting to the problem. As far as I remember on this forum, there hasn't been a case of sudden overheat or engine failure resulting from the water pump issue. It is merely the seal that starts leaking, causing a depletion of fluid and a messy clean-up. A new pump and seal is <$100, and a nice DIY.
Another common thing to fail is a small alternator control circuit, CTScott has more on that.
swidd is offline   Reply With Quote
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Alternatives to Toyota "pink" super long life coolant Camberix DIY / Maintenance / Service 10 03-30-2011 11:42 AM
coolant reservoir? toad DIY / Maintenance / Service 10 11-02-2010 11:02 AM
coolant flush/ water pump jstantherprsn DIY / Maintenance / Service 26 10-26-2010 10:36 AM
