der Zeck
VVTi Managment Greddy
http://cgi.ebay.com/ebaymotors/GREDD...98233123QQrdZ1
Have not seen one of these b4, just wanted ya'll to check it out
Interesting
#4 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
#5 | |
![]() ![]() Drives: 07 Yaris LB, 70 Mach 1, 84 5.0 Join Date: Feb 2007
Adding extra injectors is a bandaid... unless one of those injectors happens to be hooked to a tank of nitrous. Then its more like a full body cast.
The E-manage should come with any TURBO kit you buy for your car... If you drop around $3,000 and don't get one... you’re getting ripped off...
You don't need it without Forced Induction... If you want something for Naturally Aspirated Yarii... look at the: http://www.jscspeed.com/index.html?/.../pe_camcon.htm ![]() |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Nut: find me a kit for under 3K with a emanage & intercooler & I will buy it for you. You aperantly have no experiance with turbo kits. I am not trying to insult you, you just need to be more realistic with your posts. Turbo kits cost money period.
#10 | |
http://www.epsturbos.com/SCION-STAND...BO-TS25B1.view It's for a Scion Xb... but I'll convert it... When I get home to my Home PC... I can get maybe 5 or 6 other sites that show eManage for under 3 grand... but this is the best I can do from work...from memory... Since ZPI and Why are the only 2 that I have found that make Turbos for the Yaris... and they are still in production... I have to go with Scion as a Determaning factor... ZPI: http://www.zeropointindustries.net/s...roducts_id=211 WHY: http://www.whyindustries.com/store/p...products_id=51 ok...ok your right... These last 2 are a bit more then $3,000 I have been mistaken before... But anything is Possible... if you just look around! But I guess your right... I aperantly have no experiance with turbo kits. Not yet... give me a couple more months! and I will be able to say that I have baught one...Installed one... and drive a car with one! ![]() |
Good try Nut but that first turbo does not have a emanage:
What the TSI Extreme Kit comes with: 1 Garrett Turbo w/internal wastegate @ 6psi 1 High Nickel Composite Cast Exhaust Manifold 1 Downpipe 1 Fuel Pressure Regulator 1 MAP Unit 1 Oil Return Line and Fitting 1 Air Filter w/piping 1 Injection Control Unit w/Turbo Timer 1 Injector Interface Block w/Injectors 1 Blow Off Valve 1 High flow intercooler w/mounting hardware, pressure tubes, rubber hose connections and clamps Comes with everything necessary to install! Kit is a complete bolt-on! Good luck converting it, nothing from the xb will work. |
And the WHY industries also has no emanage.
ZPI still has one...for a little over $3,000... So I was $500 off... But in my defense it was on sale last month for 3Grand! That just shows how much ZPI rocks...
Alright so I'll make you a deal... I won't make you buy one for me... If take back your statement about me not knowing what I'm talking about! I have done my research on Turbos, but I am no Expert... But you have to admit I was close! ![]() |
#14 | |
![]() (Just giving you a hard time.) |
![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2006
![]() I believe the real concern is how much performance you can squeeze out of that Cam Controller from JSCSpeed. Anyone have any experience with them? |
![]() ![]() ![]() Drives: Polar White Hatch Join Date: Nov 2006
Didn't you guys read that huge post on the Scion forums where the guy tried several mods and dynoed the results? He tried the camcom thing and could not make any power. IIRC the stock ecu kept fighting it. Perhaps the Greddy unit works better?
ChinoCharles Intake supporter. |
#17 | |
I know on newer Miata's changing the VVT setting did almost nothing on engines that were only mildly modified. My gut tells me it'll be the same here. If you want to gain some power leave the VVT alone and lean out the A/F mixture, and tune the ignition setting for 91-93 octane fuel. |
I hadn't seen the one over on the Scion forums...however I stumbled upon a Celica forum and they were buying them up like hotcakes. I don't recall if it was consumers or the company, but someone had posted some dynos gaining about 10-15 horses. upon further inspection...I'm pretty sure the company posted them...and we all know how that can go!
GReddy prototype = Free Exhaust! | Chris_Lum | California | 30 | 02-27-2007 10:13 PM |
Greddy xB Supercharger | Papamoon | Performance Modifications | 2 | 02-09-2007 03:08 PM |
Opion Wanted on Greddy Infometer.... | kdctuning | General Yaris / Vitz Discussion | 5 | 01-28-2007 05:49 PM |
Will the XA Greddy cat-back fit? | Black Yaris | Performance Modifications | 8 | 12-23-2006 10:43 PM |
Greddy Intellegent Informer | the_saint | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 11-12-2006 04:26 PM |
