Old 03-10-2012, 12:27 AM   #1
Hershey
Prius C w/ 1.5 ltr. engine ( 1NZ-FXE ) uses 0w-20 ; Why not the
1NZ-FE of the YARIS ? . Here's the specs for the Prius C listing the 0w-20 , http://www.toyota.com/t3Portal/docum...df/sec_6-1.pdf . Some owners of the "C" are claiming 60+ m.p.g. at Priuschat.com . http://priuschat.com/forums/prius-c-...rted-mpgs.html . May have to trade in the '11 Fit for it .
Old 03-10-2012, 07:51 AM   #2
craigq
Drives: '07 Yaris, '12 GLI
The Prius C looks really tempting, have to check priuschat to see what "normal" owners are getting for real-world numbers...
craigq is offline   Reply With Quote
Old 03-10-2012, 08:03 AM   #3
From what I've read, it has to do with the seals on the older engines, like ours. Supposedly at high temperatures our seals could potentially allow some weeping with the super thin oil.
Old 03-10-2012, 11:57 PM   #4
Hershey
Thanks . Why is the 0w-20 allowed for all years of the YARIS in Canada ? The engines are the same and the climate here in the N.E. is quite the same as in many areas of Canada ? Makes no sense .
Tweak engine 1NZ FE bieniman Performance Modifications 23 05-21-2016 04:37 AM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Is your Yaris 1.5 Engine noisy? Yawesh General Yaris / Vitz Discussion 49 04-13-2009 11:25 AM
if i am thinking about an engine swap - from 1.3 to 1.5 - please help ASHRAF Performance Modifications 15 01-03-2007 01:40 PM
