![]() Drives: Yaris Join Date: Oct 2009
Towing a Yaris
I just bought a new Yaris and wonder if I have to disconnect the battery so the odometer won't register mileage while being towed.
Thanks, Pat G |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
37HSSV
^ That or many companies are starting to use flatbed methods.
I have seen where the car had been towed from the back up, rare though...like 1 out of every 250 tow trucks I see out there, so not to worry.
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
Learn to Relax
I just realized that a MT could be towed with the front wheels down. But that would be reverse.
![]() ![]() ![]() Drives: 08 LB BLACK Join Date: Oct 2008
If I ever have a car that needs a tow, I have had a flatbed. Anyone ever have a problem pulling a Yaris up on a flatbed?
![]() ![]() ![]() Drives: 2010 Carmine Red hatchback Join Date: Mar 2009
Double post!
#8 | |
food for thought for the worried:
KBB 07 standard auto yaris with 75000 miles: $8410 KBB 07 standard auto yaris with 78000 miles: $8410 |
#10 | |
![]() ![]() ![]() Drives: 09 3Dr Manual Join Date: Jul 2009
Just put the pedal down and let the devil take the hindquarters. |
#11 | |
![]() ![]() Drives: 2009 Yaris 3dr Join Date: May 2009
We tow our 09' 3Dr MT behind the moterhome. However, because the aux braking system needed 12volt power we leave the battery connected. I was going to pick up a haedware store key to determine if the engine imobilzer effects the battery too, but haven't had the time yet. because It really light weight it tows well.
At 2,200 lbs state regs required the AUX braking system in California. Some folks with Diesel motorhomes run the Aux brakes off the diesel's compressor. No idea how that works in a break away situation. Truthfully, don't want to find out how our system performs in break away either. but because its all "onboard" the car, I don't worry that a high pressure hose will break away before the break away ping get pulled. Setup for this kind of stuff is pricey, $5K. But I noticed the front mounting plate for the tow bar hook ups really stiffens up the front end under non towing cornering turning situations. Nice handling minimal fender flex. |
#13 | |
![]() Drives: 09 Yaris Join Date: May 2011
Thx |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Sep 2009
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| Yaris TS 1.8L History and Specs | CASTREX | Yaris TS Talk | 52 | 10-27-2009 05:06 PM |
| Towing Hitch for a Yaris | fmicle | General Yaris / Vitz Discussion | 1 | 05-16-2007 07:07 PM |
