You need a hammer and a wide flat blade screwdriver. There is a groove on the inner joint that you put the tip of the screwdriver against and then give it a sharp whack with the hammer the axle will pop right out. There is a special tool that is a slide hammer with an "L" shaped tip, but I haven't needed it.
